Capacitance in a Complicated Mixed Circuit
The discussion revolves around calculating the total capacitance of a mixed circuit involving multiple capacitors, specifically C1, C2, C3, C4, and C5, with values provided in microfarads. Participants are exploring the relationships between capacitors in series and parallel configurations.
  • Mixed
  • Participants discuss different methods for combining capacitors, with some attempting to add parallel capacitors first before addressing series combinations. There are questions about the correctness of their calculations and the steps taken to arrive at their results.
The conversation includes various attempts at calculation, with some participants expressing uncertainty about their results. Guidance has been offered regarding the approach to combining capacitors, and there is an ongoing exploration of the logic behind the calculations without a clear consensus on the final answer.
Participants are working under the constraints of homework rules, which may limit the methods they can use or the information they can assume. There is also a focus on ensuring that the final answer adheres to appropriate significant figures.
brinstar
Find the capacitance of the circuit if C1 = 10.3, C2 = 41.1, C3 = 95.5, C4 = 299.9, and C5 = 525.7, with all the units being in microfarads.
1/Series Ctotal = 1/c1 + 1/c2 ...
Parallel Ctotal = C1 + C2 + ...
I tried to combine all the parallel units first and then put it together in series, but I feel like I did it wrong. The answer I got was 241.524 microfarads. I'm pretty sure it could be right given that it's less than the smallest series capacitor (the only one I'm seeing is C5), but I'm not sure. Thank you for any help!
Well, I get a different result. So one of us is making a mistake. Perhaps you can post your steps ?
Basically, what I did was:
(1/c5) + (1/[c1+c2+c3+c4])
Then let's say the result is x.
x^-1 = Ctot.
And from that, I got around 241, give or take a few mistypes in the calculator should there be.
You can combine only two capacitors in either series or parallel at a time. Start with with C1 parallel with C3..
Ah, okay. So C1 + C3 = 10.3 + 95.5 = 105.8 microfarads?
Right. Replace this parallel combination with 105.8 microfarad and proceed.
Okie doke. So now do I add that with C4 as if they are in series?
What about C2?
cnh1995 said:
What about C2?
I meant C2, sorry! I was looking at the diagram and wrote the wrong thing >.<
So (1/105.8) + (1/41.1) = 0.0337826961 => 0.0337826961^-1 = 29.60095303 microfarads?
Right. I don't know the answer but 29.600 looks correct (it is less than the least!).
I believe you have understood the logic now. You can proceed with this technique and find the final answer. It's almost 12:30 am here, got to sleep now! Good luck:smile:!
Thank you so much for the help! :D I truly appreciate it! Have a good night!
For anyone else out there, is 202.547 microfarads the correct final answer?
Isn't that great ! If the exercise has 4 digits max, then the answer should generally have no more than 4 digits.
Ah okay, so 202.5?
PF isn't really in the business of approving answers :smile:. If you think you did it right, you did it right, right ?
I mean, just because I think I did it right doesn't mean I did it right and got it right :/ if I went with that form of logic, I don't think I'd be here asking for help and unsure of myself. I probably would've just spouted whatever I thought was logical and stuck with that answer, unaware of whether I'm objectively correct or not.
Have some faith !
And you were right when you didn't trust yourself in post #1, so maybe you are also right when you think this is the right answer!
More important: do you understand what you did and why it's correct ?
BvU said:
Have some faith !
I understand what I did, but I don't know if it's correct?
you can write your answer out using variables without plugging in numbers (which is a "better way" to solve these problems in general) then check that your units are correct. Looking at the units will help you tell if you made a mistake.
ex. if there answer is supposed to be a capacitance and your answer is C1/(C2+C3) you know your answer is incorect.
the units of C1/(C2+C3) are F/F which is unitless
You can also do a sanity check, which is saying "does this answer make sense". In some cases you might not be able to answer that question. If your answer was 500 F, you can make an argument that it doesn't make sense.
There is a meta-approach: suppose you were mistaken, then wouldn't someone have reacted and put a finger on that ? From my evasive replies you could have deduced that I got the same result as you did :rolleyes:
Have some faith :smile: !
And your reward is the fact you understand it now; the proper answer is only the cherry on the cake.
14K
