Capacitance, t=0 and t=infinity
  • Thread starter Thread starter nomorenomore
    Capacitance
At t=0, when the switch is closed, no current flows through the circuit as the capacitor has not yet charged, resulting in zero voltage across the capacitor. As time progresses to infinity, the capacitor becomes fully charged, and the current in the circuit approaches zero while the voltage across the capacitor equals the electromotive force (ε). The relationship between charge, voltage, and current is governed by the equations provided, where the current decreases as the capacitor charges. The resistance of a capacitor is considered infinite, indicating it does not conduct current once fully charged. Understanding these concepts is crucial for solving the problem accurately.
nomorenomore
1. Referring to the picture, switch S1 is closed at t=0.
a) What is the current in the circuit loop at t=0 and t=∞?
b) What is the voltage on C at t=0 and t=∞? (4M)
(Picture's Link: http://s29.postimg.org/bfsbw2hc5/physexam1q7.png)
When charging,
1.) ε - iR - q/c = 0
2.) max. current = -ε/R
3.) max. charge = C*ε
4.) q = Qfinal(1 - e^(-t/(RC))
5.) i = (Qfinal/RC)*e^(-t/(RC))
a) In fact I don't understand what t = 0 means. So when t = 0, is there any current yet?
For t = ∞, I tried to sub t = ∞ to equation 5) and use equation 3) to find the Qfinal. But it doesn't seem correct. Should I do it this way?
b) When t = 0, voltage on C = ε - iR? I assume the current has already thrown through the circuit when t = 0?
For t = ∞, should I sub t = ∞ into equation 5)? But it seems i = ∞ then? doesn't seem correct. :H
Very confused.:( Please help.
(Plus, how do we calculate the resistance of a capacitor? When I google it, I found someone said it's assumed to be zero. So in calculation, I assumed its resistance to be zero?)
When charging,
Initially, the switch is open. No current flows and there is no charge on the capacitor. You start measuring time at the instant when you close the switch. Current starts to flow, but there is no charge on the capacitor yet.
What did you get for the current at t = ∞?
You should know how the voltage on the capacitor is related to the charge on it, and that the charge is increased in the rate of current flow..
Current flows onto the capacitor till the voltage across the capacitor is less than the electromotive force ε. At t=0, the charge is 0. What is the current then according to equation 1.)?
As the charge accumulates on the capacitor, the capacitor voltage Uc increases and the voltage across the resistor Ur decreases. As i=Ur/R , the current decreases. After very long time the capacitor voltage become very close to the emf and the currents tends to zero.
Try to sketch how q and i changes with time according to 4.) and 5.).
The capacitor has infinite resistance. It has capacitance. The voltage is proportional to the charge Uc=Q/C.
