Capacitor charged then disconnected
  • Context: Undergrad
  • Thread starter Thread starter member 392791
    Capacitor Charged
This discussion focuses on the behavior of capacitors when a charged capacitor is disconnected from a battery and then connected to an uncharged capacitor. It clarifies that when capacitors are connected in series, they share the same charge, while in parallel, they maintain the same voltage. The conversation emphasizes that the conservation of voltage applies in both configurations, but the charge distribution can differ based on the initial states of the capacitors. The participants also explore a specific homework problem involving a 10.0 µF capacitor charged to 15.0 V connected in series with a 5.00 µF capacitor, ultimately determining the new potential differences across both capacitors.
  • Understanding of capacitor charging and discharging principles
  • Knowledge of series and parallel capacitor configurations
  • Familiarity with basic electrical circuit concepts
  • Ability to apply formulas for capacitance, charge, and voltage
  • Study the principles of capacitor charge conservation in series and parallel circuits
  • Learn how to calculate equivalent capacitance for series and parallel configurations
  • Explore the effects of connecting capacitors with different initial charges
  • Investigate practical applications of capacitors in electronic circuits
Electrical engineering students, electronics hobbyists, and anyone interested in understanding capacitor behavior in circuits will benefit from this discussion.
member 392791
Hello,
I am confused as to what happens when a capacitor is charged by a battery, disconnected, and then connected to a second uncharged capacitor.
Is the situation different for whether the two capacitors are connected to each other in series or parallel?
If in series, shouldn't the charges be equal on both capacitors, and if connected in parallel, they are both the same voltage.
Of course, I was thinking is there such a thing as connecting the capacitors in series or parallel if they are the only part of the circuit, meaning that connecting something in series or parallel is exactly the same thing if there is no battery part of the circuit.
Indeed, I can't imagine more than one way of connecting the capacitors into a single circuit.
Well, you could take both leads from one capacitor and connect them to a single lead of the other capacitor, but that (a) doesn't make a complete circuit that contains both capacitors, and (b) instantly "shorts out" the first capacitor.
As you already noticed, without the battery the two capacitors are in parallel and also in series at the same time. And since they are in parallel their voltage will be the same. The charge however isn't necessarily equal. The rule that capacitors in series have the same charge only applies if both capacitors were originally uncharged.
Assuming no leakage or losses, I'm wondering if potential (voltage) should be conserved for both cases, when one plate from each capacitor is connected (series) or when both plates of each capacitor are connected (parallel).
Woopydalan said:
Hello,
Assuming the capacitors are not polorized there should only be one way to connect them together. Your question about series or parallel makes no sense. Or maybe I'm misinterpreting your question. Whatever the problem you're having, this webpage may help clear some things up for you. It explains how energy is lost in the process of charging or discharging a capacitor.
http://www.smpstech.com/charge.htm
In the diagram from the web page you linked to:
Diagram (A) show the capacitors already connected in "series". If the switch in (A) included a circuit, then connecting up that circuit as shown in (A) would be using the capacitors in series. Getting back to what I think is the original question, using diagram (A), imagine that intially there is no connection between the capacitors, such as an open switch at the bottom of the diagram, the capacitor on the left is charged, and the capacitor on the right is uncharged. When the bottom connection is made, the bottom plates of both capacitors are connected, and depending on the initial states (charge bias) of the two capacitors, charge could be transferred. For example, the uncharged capacitor could have have any charge on both plates, as long as the charges were equal. For the charged capacitor, the only known is that the difference in charge x distance corresponds to it's voltage, but the actual amount of charge on each plate is unknown. In this circumstance, regardless of the initial charged state, I suspect that the total voltage after connecting the bottom two plates of the capacitors will remain constant.
Diagram "B" shows the parallel case, where voltage is conserved, which what I thought should happen. This can get complicated if the capacitors are unlike, such as a different distance between plates. To use the capacitors as a "parallel" source, you'd need to connect a circuit in parallel to the top and bottom halfs of the loop shown in diagram (B).
Ok here is why I am finding myself confused.
I had a homework problem stating
A 10.0 uF capacitor is charged to 15.0 V. It is next
connected in series with an uncharged 5.00 uF capacitor.
The series combination is finally connected across a 50.0-V
battery, as diagrammed in Figure P26.62. Find the new
potential differences across the 5 uF and 10 uF capacitors.
Well, the dang problem said that they are connected in series. This would imply that there is such a thing as connecting them in parallel if they would differentiate, so I figured that there were two different ways.
By the way I'm not asking this as a homework question, I was just pointing out that the problem stated that it is then connected in series, with the implications previously stated.
Also, I thought that being in series meant they had the same charge, but apparently that rule only applies if they were both initially uncharged (not mentioned in the textbook).
I think what they mean here is that the capacitors first get connected with a single connection, i.e. no "circuit" yet. Then, second, the 50V battery connects the open ends of the caps to complete the new circuit.
That is correct, emi guy. How did you abstract that information from the way the question was worded? It sounds to me like you make a circuit with the two capacitors, let charges move around, then plug it to the 50 V battery.
I think you're saying that we first charge a capacitor ' A' with battery 'B'. then we wait 5 secs for the capacitor to get charged and then we throw the battery 'B' and place another capacitor 'C' in its(B's) place,with our insulating gloves.
I think the charge would be conserved and potential difference across them should be same. By this we get two equations and can find charge stored on both the capacitor(in final situation) in terms of their capacitance and potential of battery
Sorry for a foolish question.
But I'm looking at 3 capacitors in series that have a charge of 150 uC each. When you make an equivalent capacitor, the charge on the equivalent capacitor is 150 uC. Why isn't it 450 uC? Where did those other 300 uC of charge go?
At the instant the capacitors are connected with a single connection, there could be a brief moment of current depending on the charge bias of the capacitors. If the "uncharged" capacitor had a positive charge bias (positive and equal charge on both plates), and a single connection was made to the other capacitor to a plate with a negative charge, then there would be a brief moment of current between those plates. Depending on the charge of the other pair of plates, the equilbrium state of the two connected plates may be one where the charge on both plates is not the same, due to attraction or repulsion of charge due to the other pair of plates.
The issue is that after the single connection, connecting the pair of capacitors to a circuit could end up using the capacitors in series or in parallel.
Assuming the 3 capacitors are identical, the equivalent capacitor should be 50uC, with triple the voltage.
Wiki article:
http://en.wikipedia.org/wiki/Capacitor#Networks
Wow, I do not know how to solve that. If I have more time later I may try to figure it out. What book is it in?
The charge in a capacitor is between the two plates. Wouldn't you have to have a circuit between those two plates to change it? I guess there could be a very very brief current due to capacitance around the outside of the capacitor, but it would normally be so small as to be undetectable.
I meant the actual charge on the plates. Imagine the plates are large enough and can hold enough charge that you can create a static spark just by bringing two plates with different amounts of charge close to each other. A sudden connection between plates of differing charges could involve some brief moment of current flow, depending on the charges on the other pair of non-connected plates.
Initial situation:
C1 = 10µF
V1 = 15V
Q1 = 10µF * 15V = 150µC
C2 = 5µF
Q2 = 0µC
Final situation:
V = 50V
V1 + V2 = V
Q1 = Q2 + 150µC
V1 = 15V + Q2/10µF
V2 = Q2/5µF
=> 50V = 15V + Q2/10µF + Q2/5µF
50V - 15V = 3Q2/10µF
350µC = 3Q2
Q2 = 116.67µC
Q1 = 266.67µC
V2 = 116.67µC/5µF = 23.33V
V1 = 266.67µC/10µF = 26.67V
  • · Replies 16 ·
  • · Replies 103 ·
  • · Replies 19 ·
