Capacitor with partially inserted Dielectric
The discussion revolves around calculating the voltage across a parallel-plate capacitor when a dielectric is partially inserted. The dielectric constant (K) is determined as the ratio V_1/V_2 when the dielectric fully occupies the space. For the scenario where the dielectric fills one-third of the space, the voltage can be calculated using the equivalent capacitance of two capacitors in parallel, leading to the formula V_f = (3V_1V_2)/(V_1 + 2V_2). This approach emphasizes the importance of charge conservation and the differing charge densities in regions with and without the dielectric.
  • Understanding of parallel-plate capacitors
  • Knowledge of dielectric materials and their properties
  • Familiarity with capacitance equations, specifically C = Q/V
  • Basic principles of electric charge conservation
  • Study the concept of dielectric constants in various materials
  • Learn about the derivation of capacitance for capacitors in parallel
  • Explore the effects of inserting dielectrics on capacitor performance
  • Investigate the relationship between charge density and voltage in capacitors
Students studying electromagnetism, electrical engineers, and anyone interested in capacitor design and analysis.
joshanders_84
This is one of my homework problems that I am stumped with:
A parallel-plate capacitor with only air between the plates is charged by connecting it to a battery. The capacitor is then disconnected from the battery, without any of the charge leaving the plates.
A) A voltmeter reads V_1 when placed across the capacitor. When a dielectric is inserted between the plates, completely filling the space, the voltmeter reads V_2. What is the dielectric constant of this material?
I know the answer to this: it is V_1/V_2 (as the definition of K).
B) What will the voltmeter read if the dielectric is now pulled partway out so it fills only one-third of the space between the plates?
I don't understand how to answer this one. I have tried going into the definition of capacitance with and without a dielectric, and came up with V_1/(k/3), but that is not the right answer. I don't understand how to figure this out...any and all help is much appreciated. Thank you
Use the equation C = Q/V = (epsilon*S)/d
In the case when you only have free space what is V1?
For the case where you have 1/3 dieletric and 2/3 free space you can split the problem into two capacitors in parallel.
In that case, shouldn't it be (1/3)V_2 + (2/3)V_1? I have tried that but it is incorrect and I really just don't seem to get it.
Um, no. I believe the answer should only have a V1.
Remember that the total charge doesn't change, but the charge density in the region with the dielectric will be different from the region without. The charges must end up distributed so that the voltage is the same everywhere on the plates.
Ed: Solve for Ceq as dduardo suggested. Then find an expression for Q in terms of V1 and use the fact that Ceq = Q/Vf
PS: I wouldn't stake my life on it, but my answer has both V1 and V2 in it. :smile:
But in this case, Ceq is equal to what? I mean how can I solve for that?
In effect you have 2 capacitors in parallel, so use
\frac{1}{C_{eq}}=\frac{1}{C_1} + \frac{1}{C_2}
You can express C1 as a function of ε0, d, A, and V1 and C2 as a function of ε0, d, A, and V2.
Put all of that together, along with the knowledge that Q is a constant that you can express as a function of ε0, d, A, and V1 or V2, will give you the answer.
gnome, the equation you gave is for capacitors in series. You just add the capacitor values in parallel: C1+C2+...Cn
Hmmm...resistance, capacitance... can't keep 'em straight after 1 year
Yes, you're absolutely right. Thanks.
So,
C_{eq}={C_1} + C_2
gives me
V_f = \frac{3V_1V_2}{V_1 + 2V_2}
Do you agree?
  • · Replies 17 ·
