Capacitors charged in parallel
L_landau
Capacitors C1 = 6.97 uF and C2 = 1.54 uF are charged as a parallel combination across a 281 V battery. The capacitors are disconnected from the battery and from each other. They are then connected positive plate to negative plate and negative plate to positive plate.
A) Calculate the resulting charge on capacitor C1.
B) Calculate the resulting charge on capacitor C2.
from this answer
http://www.chegg.com/homework-help/questions-and-answers/capacitors-c1-697-uf-c2-154-uf-charged-parallel-combination-across-281-v-battery-capacitor-q1385340
Q = CΔV
So q1 = 1.5x10-3c and q2 = 5x10-4c. Why would the drawing show opposite polarizations on the plates? Shouldn't the battery give the same potential drop across two capacitors in parallel?
  • Circuit diagram of two capacitors C1 and C2 in parallel, each drawn with plate signs; C1 is top with red plus on left plate and blue minus on right, C2 is bottom with blue minus on left plate and red plus on right.
L_landau said:
from this answer
That answer is visible only to chegg members.
Because,
But the picture is as they are charged and before they are connected positive to negative and vice-versa I thought?
No. It is just after they are reconnected in series.
That would be true when the capacitors were charging.
