Car braking and ratio of force of friction
The discussion centers around the physics of car braking, specifically the forces acting on the front and rear brake pads during deceleration. The problem involves calculating the ratio of the force of friction on the front tires to that on the rear tires, given certain parameters such as mass, deceleration, and dimensions of the car.
  • Participants discuss the use of free body diagrams (FBD) and torque to analyze the forces acting on the car. There is uncertainty about how to set up the problem correctly, particularly in finding the normal forces on each tire and how they relate to the torques involved.
Participants are exploring different methods to approach the problem, including the use of FBDs and torque balance. Some guidance has been offered regarding the need to consider the normal forces and their relationship to the overall weight of the car, but there is no explicit consensus on the method to be used.
Participants are working under the assumption that the coefficients of friction are equal for all tires and that the car is skidding during deceleration. There is a focus on understanding the balance of forces and torques without providing a complete solution.
smhippe
The front brake pads on your car wear out faster than the rear brake pads; in fact,
some cars are specifically designed with large front brake pads because of this. This
results from the fact that when a car is braking the magnitude of the friction force acting
on the front wheels of the car is larger than the magnitude of the friction force acting on
the rear wheels of the car. Consider a car that has a mass of 1500 kg that is decelerating
(by using the brakes) at a rate of 0.25 g. The distance between the front and rear axles is
2.8 m and the center of mass of the car is directly in-between the two axles at a height of
0.6 m above the ground. What is the ratio of the force of friction acting on the front tires
to the force of friction acting on the rear tires? Assume that the coefficients of friction
between the tires and the road are the same for all tires and, for simplicity, assume that
the car is skidding as it decelerates.
First I set up a FBD. That didn't seem right...at all. So now I'm thinking about using torque. I don't really know how to set this up.
The torque from the frictional force, must be balanced by a torque that comes from the difference in the normal force acting on the front and rear tires.
That means I have to find the normal force on each tire first then right? I can do this by using the FBD and substituting?
You can certainly use the FBD diagram to find out what the torques acting on the car are. (force * distance to center of mass). I don't know what you mean by substituting.
The torques from friction, normal force on the front wheels, normal force on the back wheels has to be equal to 0.
Of course the sum of the normal forces on the wheels has to equal the weight of the car as well.
  • · Replies 19 ·
  • · Replies 25 ·
  • · Replies 17 ·
