Car Collistion using conservation of momentum
The discussion revolves around a collision between two cars at an intersection, specifically analyzing the conservation of momentum. The yellow car is moving south and collides with a stationary green car moving west. Participants are tasked with finding initial velocities, impact velocities, and momentum, while considering the effects of kinetic friction and skid marks.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants explore the use of conservation of momentum and question the assumptions regarding the inelastic nature of the collision. There are discussions about the relevance of skid marks and the impact of friction on the calculations. Some participants suggest working backwards from the final velocities after the impact to determine initial conditions.
The discussion is ongoing, with participants providing guidance on the steps to take in calculating the velocities and momentum. There is a recognition of the need to clarify the process, particularly regarding the yellow car's velocity after the impact and how to apply conservation of momentum effectively. Multiple interpretations of the problem are being explored, but no consensus has been reached yet.
Participants note that the use of energy or time is restricted according to the tutor's guidance, which adds complexity to the problem-solving process. There is also uncertainty about the relevance of certain data points, such as the length of skid marks and the initial conditions of the cars involved.
Celestial92
Two Cars
Yellow: Moving South
Green: Moving West
Green car stop in center of intersection and gets hit on from south bound Yellow Car
They collide, at intersection, find initial velocity, impact velocity and momentum (this confuses me)
Yellow Mass - 1356 kg
Green Mass - 829 kg
Skid Marks
North-South - 13.18m
East-West - 11.2m
Curved Skid - 3.442 (don't know how relevant)
Yellow front tire is 18.35m from southern end of north-south skids marks (again, not sure how relevant)
Kinetic Friction - 0.8
According to tutor, not able to use energy or time at all. Conservation of momentum should be enough.
I THINK the collision is inelastic and total momentum is conserved.
[itex]v^2 = u^2 + 2as[/itex]
[itex]m_1v_1 + m_2v_2 = m_1v_1 + m_2v_2[/itex]
I believe I was able to figure out the initial velocities, but don't know how to proceed or even if I am correct.
Friction Force = (-0.8) * (9.81) = -7.84 m/s^2
Yellow
[itex]u^2 = v^2 + 2as[/itex]
[itex]u^2 = 0 + 2 * -7.84 * 13.18[/itex]
[itex]u^2 = -206.66[/itex]
[itex]u = \sqrt{266.66}[/itex]
[itex]u = 14.37 m/s[/itex]
Same for Green car to get 13.25 m/s
Please help if you are able, the first set of answers (using time and energy) were not accepted as I didn't know you couldn't use them.
I agree with your calculation for the green car but not the yellow.
The green car is stationary when hit so the 11.2m east west skid mark can be used to work out it's initial velocity.
The friction force = 0.8 * mass * g
F = m * a
a = F/m = 0.8 * g
V2=U2 + 2as
U2 = - 2as
U = SQRT (2 * 0.8 * g * 11.2)
= 13.25m/s (eg same as you got).
However the yellow car undergoes a three part process..
1) The initial skid reduces the velocity but does not stop the car.
2) An impact
3) A second skid to a stop.
I believe you have to work the problem backwards. Taking part 3 first.. You can work out how fast the yellow car was going after the impact from the length of the second skid.
You then need to apply conservation of momentum to work out how fast the yellow car was going before the impact. To do that I believe you also need to work out the velocity of the green car after the impact from it's second curved skid.
At this point you will have the velocity and mass of both cars after the impact so you can sum the momentum after the impact.
You know the momentum of the green gar before impact (=0) so easy to work out the momentum of the yellow car at impact.
Then calculate the velocity of the yellow car at impact.
Finally the velocity of the yellow car at the start of the initial skid.
Just to clarify..
I believe this bit of your calculation...
Yellow
is wrong because the yellow car does not stop at the end of it's first skid so V2 is not zero. I believe you need to calculate V from what happens after the impact.
Ok, I will do those calculation in the morning.
So I'm 100% on this, the process is.
1. Find Velocity of Yellow after impact
2. Then impact velocity
3. Initial velocity of yellow
4. Then apply conservation of momentum steps
Also, am I able to get 1-3 from the previously used equation or what I have to use something else
No.
1. Find Velocity of Yellow car after impact
2. Find Velocity of green car after impact
3. Apply conservation of momentum to calculate Velocity of yellow car at impact (green car is stationary).
4. Calculate Velocity of yellow car at start of first skid.
1. and 2. come from V2=U2+2as. For both cars V2=0 and you need to calculate U.
4. also comes from V2=U2+2as. In this case V comes from step 3 and you need to calculate U.
  • · Replies 18 ·
9K
