Car Modification: Using your battery to prevent rust
  • Thread starter Thread starter paradoxlost
    Battery
21 replies · 2K views
paradoxlost
TL;DR
using your battery to prevent rust
Hypothetically speaking, if you wanted to prevent rust on your car frame, how would you wire your battery to your frame?
paradoxlost said:
TL;DR Summary: using your battery to prevent rust
The efficacy of electronic rust protection for cars is controversial. For example, from: https://www.autotrainingcentre.com/blog/truth-electronic-rust-protection/
Electronic rust protection has received mixed reviews from customers. While many will enthuse about its capabilities, there seem to be an equal (if not larger) segment who claim the process is overpriced and ineffective. While rustproofing your vehicle is definitely encouraged, sprays and waxes are often the more recommended options, and have been proven to work over the years. Experts pursuing automotive careers do not believe there is substantial evidence regarding the efficiency of an electronic rustproofing system, or that it works better than other options like waxes.
The technology itself is based on the models used on the bottom of boats. In addition to other arguments, many say that electronic rust protection for cars therefore only truly works when fully submerged in water. There are to date no official reports which show that cars with electronic rust proofing have less corrosion than they would without the device.
So how are they doing it where it doesn't work? and why wouldn't it work?
Google "boat cathodic protection" for many references to marine rust protection systems. An essential element of these systems is the flow of currents in the water surrounding the boat hull. No analogous currents flow in the atmosphere around an automobile, hence the skepticism expressed in post #2.
so your saying you'd have to install some sort of secondary system that provides a steady flow of electrons?
Yes, but I believe that secondary system would have to supply current broadly over the surface areas of the car frame and body that you want to protect (just like water does for a boat hull), not just through, say, discrete wires connected to isolated points on the metal.
what if you didn't do on the undercarriage and you used like graphene sheets above the frame, with maybe some sort of contact on the undercarriage?
Well, you'd have to map or model the current flows through the sheets to make sure the distribution provides wide coverage. And if you're going to all the effort to cover the vulnerable frame surfaces with close-fitting graphene, why not instead just apply standard, proven rust-inhibiting coatings like paints, polymers, oils, waxes, etc. that don't require an additional electronic system?
Idk, cause I can?
Or because electromagnetic fields don't create particulate pollution.
If a current flows between two parts of a vehicle, corrosion will be stimulated at some contact in that circuit.
It is better to paint or powder-coat all surfaces, that will prevent conduction and corrosion of metals.
Above all, if water is present, you must prevent chlorine from salt, coming into contact with iron.
so you just have a the cathode end of the contact be some metal resevior that your replace
paradoxlost said:
so you just have the cathode end of the contact be some metal reservoir that you replace
The use of a sacrificial anode, requires that the anode be immersed in an electrolyte. The anode metal is dissolved, and passes into the electrolyte, so some metal will be plated onto the cathode, which is the metal structure you want to protect.
How do you arrange the electrolyte reservoir to create a circuit?
Averagesupernova said:
Or, you could drive your car in a lake....
perhaps the coolant or some analogous situation?
The coolant system is a closed internal system, that is protected from corrosion by inhibitors in the coolant.
The manufacturer was careful to select materials and a coolant that would not corrode. If you pass a current through any part of the internal cooling system, you will force corrosion, not reduce it.
You cannot protect a vehicle from corrosion without either; (1) keeping all exterior surfaces covered by a protective surface treatment, or (2) keeping it underwater with a sacrificial anode like a boat hull.
I just don't buy that. It seems like a solvable problem. We may not have the material science for it yet, but it doesn't seem like that difficult of an issue.
The electrochemistry of corrosion is very well understood, as is circuit theory. What you are asking for, is provably impossible.
Magic is not an acceptable solution on PF.
If it's not difficult why don't you just go do it?
Thread has been closed temporarily (by a different Mentor) for Moderation review.
