Carbon Fibre Flywheel (for energy storage)
The discussion revolves around the feasibility and design considerations of creating a carbon fiber flywheel for energy storage, particularly in automotive applications. Participants explore material choices, structural integrity, energy storage efficiency, and potential mechanical challenges.
  • One participant questions the suitability of carbon fiber for flywheels, suggesting that heavier materials would be more effective for energy storage.
  • Another proposes a hybrid design using a steel cylinder surrounded by carbon fiber, aiming to optimize energy storage for automotive use.
  • A participant discusses the balance between maximum energy storage and the risk of disintegration at high RPMs, suggesting that carbon fiber could outperform steel in terms of energy storage due to its ability to spin faster before failure.
  • Historical context is provided regarding past attempts to use flywheels in coal mining applications, noting that the feasibility of such designs may have been limited.
  • Concerns are raised about the gyroscopic effects, friction, and safety implications of high-speed flywheels in vehicles, emphasizing the need for careful design to mitigate risks.
  • Innovative ideas are shared about alternative energy storage methods, including using gas pressure and magnets to manage energy input and output in a flywheel system.
  • A reminder is given about the importance of precise balancing in flywheel design to ensure stability during operation.
Participants express differing views on the appropriateness of carbon fiber as a material for flywheels, with some advocating for its use while others argue for heavier alternatives. The discussion remains unresolved regarding the best approach to design and implement a flywheel for energy storage.
Participants note various challenges, including the need for balancing, managing gyroscopic effects, and ensuring structural integrity at high speeds. There are also references to historical attempts at flywheel applications that did not yield successful outcomes.
This discussion may be of interest to individuals exploring energy storage solutions, automotive engineering, materials science, and those curious about innovative mechanical designs.
nuncoop
Is it difficult to make? as a complete beginner, what do I need to know, and am I way in over my head? :) any help would be appreciated.
If you were making a flywheel that is meant to store energy, you would want it to be made out of a nice heavy material to avoid having to spin it too fast. For this reason, carbon fiber is probably the WORST material that said flywheel could be made out of.
What about a steel cylinder encompassed by an outer cylinder of carbon fibre? My goal is to incorporate it into a car as the main power source.
Maximum energy stored for the weight necessitates high rpm. Disintegration on overspeed is the problem. Steel becomes shrapnel. Carbon fibre becomes fuzz. For the weight carbon fibre should be able to store more energy than steel as it will be able to spin faster before destruction. The wheel is shaped such that a planned band near the rim is formed with less thickness so that on overspeed only the rim disintegrates. Like a shear pin.
Some work was done to in the late 70's to incorporate a flywheel in a coal mine in Pennsylvania, I believe. The shuttle car was to have a 5 flywheel package where the cable reel was. The flywheel would provide thru a gear box hydraulics, lights, tram and conveyor power for 20 minutes. Idea was at the feeder when dumping coal to contact the power supply and spin the wheels back up. I never did hear how the tests went. I saw that in an old Mechanix Illustrated. Since 30 years from that I've never heard of such in the coal fields I'd say that normal mining "stop and go" methods proved the idea not feasible in that application.
I think some trolley cars on the west coast were using flywheels to go beyond the trolley wire a short distance.
Still, the fibreglass and Kevlar wheels could hold considerably more energy per pound than steel because they could be spun faster.
Being in a car you would have to deal with gyroscopic effects. Friction. Shielding if the wheel fails. Power input and ouput. These things at speed are literally a bomb and must be respected as such.
I have sought some means to keep the speed down and yet still store energy. I have thought of a tube with a piston pressing on a gas that when sufficient pressure is achieved that a phase change would store energy toward the rim as it pulled a vacuum on the axle side. Or vice versa. Thus at a given temperature the wheel would move the piston back and forth thus altering the rpms of the wheel.
I thought of using magnets in a similar manner. Mount a permanent in the outer end of a pipe and another that when at speed is centrifugally pushed toward the end one and is repelled as the two North ends face each other. The faster the wheel the nearer the magnets get and the more repulsion they feel. Or somehow use electro magnets in a similar way.
The goal is to pump energy into the wheel other than kinetically. The main storage would be in a narrow range of rpm's. Yeah that be the goal.
Just some thoughts.
Don't forget you gotta' balance them spinners to a gnats ass.
  • · Replies 21 ·
  • · Replies 29 ·
