Carbon Steel for High T pipeline
  • Thread starter Thread starter Iron_Woman
    Carbon Steel
The discussion focuses on designing a pipeline distribution system for high-pressure (1900 psi) and high-temperature (650 ºF) steam injection into oil wells. The original design using B31.1 code resulted in a pipe thickness of 2 inches, which is insufficient due to low steel strength. Recommendations include using martensitic stainless steel alloys like AISI 420 (X20Cr13) for better strength and corrosion resistance at elevated temperatures. Additionally, considerations for insulation and the potential hazards of high-pressure pipelines are emphasized.
  • Understanding of ASME B31.1 and B31.3 piping codes
  • Knowledge of materials science, specifically martensitic stainless steel
  • Familiarity with pipeline design for high-pressure and high-temperature applications
  • Awareness of corrosion and erosion factors in pipeline systems
  • Research martensitic stainless steel properties and applications in high-temperature environments
  • Study ASME B31.1 and B31.3 codes for high-pressure piping systems
  • Explore insulation techniques for high-pressure steam pipelines
  • Investigate the corrosive properties of supercritical water and its impact on pipeline materials
Engineers and designers in the oil and gas industry, materials scientists, and professionals involved in high-pressure pipeline systems will benefit from this discussion.
Iron_Woman
This is my problem: I need to design a pipeline distribution system for steam service. But is thought in order to inject high P, high T steam into oil wells (upstream industry). Inlet conditions into the pipeline will be 650 ºF, 1900 psi. Pipes are several km long, and, because it is a network, diameters vary. My flowrates are quite high, so it would be good to use some 30" pipelines.
I was designing with B.31.1 in order to get a pipe thickness, but the materials I found there give me about 2" thickness for 30", due to the low steel strenght.
Is there any material suitable for my application?
Thanks
Thanks
I believe 2 inches (5.1 cm) is in the ball park. High pressure (2500 psi) and high temperature (up to 700 F) has wall thickness on the order of 2.6 to 3.2 inches (6.6 to 8.1 cm) for nuclear power systems. The piping is often centrifigual cast, while elbow and fittings are statically cast.
Here are some examples of materials:
http://www.petrosteel.ca/ocgt/high_pressure_seamless_pipes.html
And one should apply the appropriate code. It would difficult to use a material not covered by ASME code: B31.1 or B31.3.
Here is an example - http://www.psig.sg/Don/B31.3 Process Piping Course - 17 High Pressure Piping.pdf
A high pressure (2000 psi) pipeline is potentially hazardous. Corrosion and erosion are critical aspects. Depending on the geographic location, the piping should be appropriately insulated.
Depending on the size of the system, it might be better to place the steam generator near a set of wells rather transport high pressure steam over km of pipeline.
In an oil well, some km are vertical, so producing the vapour near the use isn't easy.
For such T and P, carbon steel may not be optimum. You might give an eye to martensitic stainless steel: vapour turbines use alloys very similar in composition to Aisi 420 (=X20Cr13), which keeps essentially their good strength at this temperature, even over time, as Cr avoid long-term softening.
Cr (but no Ni) makes them somewhat more expensive than carbon steel, but the better strength at heat allows to reduce the sections, which may save cost (or not). Their resistance to corrosion by steam is good.
Some such alloys add a bit of Ni (1.4057, 19-4...) or V, Mo... (modified Aisi 420) to improve corrosion resistance or strength, but these are details over the cheap and common X20Cr13.
Also, they are sometimes tempered at 280°C instead of 650°C for better yield strength, but I wouldn't go that way for service at 340°C.
Thats really extreme conditions. you are probably approaching if not at supercritical conditions for Water and Other gases that may exist in your pipeline. You should probably review literature pertaining to the corrosive properties of supercritical water.
The alloys I suggested are used in vapour turbines.
10K
9K
