Carnot Engine Between Reservoirs with Varying Temperatures
The discussion focuses on calculating the maximum work obtainable from a Carnot engine operating between two reservoirs with varying temperatures. The initial equations involve the efficiency of the engine and the relationship between heat transfer and temperature changes. Participants suggest using the first law of thermodynamics to relate the work done to the heat exchanged between the reservoirs. There is an emphasis on finding a relationship between the temperatures of the two gas containers to facilitate integration. Ultimately, the correct approach involves determining the final equilibrium temperature and correcting any sign errors in the calculations.
doombanana
Two containers with fixed volume are each filled with n moles of a monatomic ideal gas with constant heat capacity. Initially, the volumes of gas are at temperatures T_1,iand T_2,i. What is the maximum amount of work that can be obtained by operating an engine between the two containers?
Let T_1 > T_2
(1) \eta = \frac{|dW|}{|dQ|} = 1 - \frac{T_2}{T_1}
(2) |dQ| = -c_vdT_1 because |dT1| is negative so |dQ| = -dQ
(3) c_v = \frac{3}{2}nR
Substituting (2) into (1) and solving for |dw|gives
|dW| = -c_v \Big(1 - \frac{T_2}{T_1}\Big)dT_1
I need to integrate this somehow, but both T1 and T2 are changing so I'm not sure how to do this. I'm assuming there's a relationship between T1 and T2 that I can use that will allow me to integrate? Any help pointing me in the right direction would be greatly appreciated.
Try coming up with a relationship between T1 and T2. You should be able to calculate how much heat of the dQ taken from the hot reservoir is expelled into the cold reservoir, which you can then use to get the change in T2.
Hello doombanana. Welcome to PF!
Try setting up an equation for the the cooler gas similar to your equation (2). Also, I think you'll need to use the 1st law of thermodynamics to relate dW, dQ1, and dQ2.
vela said:
Try coming up with a relationship between T1 and T2[/sup]. You should be able to calculate how much heat of the dQ taken from the hot reservoir is expelled into the cold reservoir, which you can then use to get the change in T2.
I guess finding this relationship is where I'm having trouble.
Using Tsny's suggestion, from the first law I found that
1- \frac{|dQ_2|}{|dQ_1|}= 1-\frac{c_vdT_2}{-c_vdT_1}=1-\frac{T_2}{T_1}
solving the last two parts of the equation for T2 gives
T_2=\frac{T_1c_vdT_2}{-c_vdT_1}
substituting that into my eq for |dW| gives
|dW|= -c_v( dT_1 - dT_2)
integrating gives
|W| = c_v(T_{1,i}-T_{2,i})I know this isn't right because |W| ends up being larger than |Q_1|, but I'm not sure where I went wrong, or if this is even remotely close to the correct way to go about this. (I have a feeling it's not.)
EDIT: when integrating I assumed that the final temperature in both reservoirs was equal to (T1,i + T2,i)/2 which now I'm thinking isn't the case. If so, I'm even more lost than before.:rolleyes:
Thank you! I don't know how I've made it this far without creating an account here.
OK!
Check for a sign error inside the parentheses.
integrating gives
You'll see that with the sign corrected in the previous expression, the integrated expression for W will include the final equilibrium temperature.
EDIT: when integrating I assumed that the final temperature in both reservoirs was equal to (T1,i + T2,i)/2 which now, I think, isn't the case. If so, I'm even more lost than before.:rolleyes:
See if you can find the final temperature by integrating your equation
Just a note. You can apply the 1st law to the entire process as
W = |Q1|-|Q2|
Each Q can be expressed in terms of Cv and the overall temperature changes. This avoids having to first set up an expression for dW and integrating. But the result is the same.
You're still going to need to determine the final equilibrium temperature in terms of the initial temperatures.
Sign errors are the bane of my existence, but at least I see where it came from.:smile:
Got it!
W = |Q1|-|Q2|
Oooh, that is a bit of a shortcut and a more intuitive of setting up the problem.
Thank you very much for your help! You've saved me hours of beating my head against the wall.
