Solving Entropy of Carnot Engine for Homework
In summary, the conversation discusses the process of boiling a pot of water by inserting a Carnot engine between a reservoir at 100C and the pot at 20C. The Carnot engine operates between two temperatures, absorbing heat from the reservoir and rejecting it to the pot while also generating work. The total entropy of the system remains the same in this process, as shown by calculating the entropy changes for the reservoir and pot. However, the process must be done in a reversible manner, which involves an arbitrarily large number of cycles of the heat engine to maintain a constant temperature for the pot.
tjackson3
150
You want to boil a pot of water at 20C by heating it to 100C. I suggest a way of heating the pot in a reversible manner: simply inserting a Carnot engine between the reservoir (at 100C) and the pot. The Carnot engine operates between two temperatures, absorbing heat [tex]dQ_1[/tex] from the 100C reservoir and rejecting heat [tex]dQ_2[/tex] to the pot at temperature T (heat capacity C). At the same time, work [tex]dW[/tex] is generated in this process (n.b.: I don't know if this is relevant; it was used in the second part of the question). Starting from 20C water temperature, receiving heat in a reversible manner, the pot of water reached 100C.
Show that the total entropy of the system (reservoir + pot) remains the same in the process. Ignore the heat capacity of the pot and the temperature dependence of the water heat capacity.
For a Carnot engine:
[tex]\frac{Q_H}{Q_L} = \frac{T_H}{T_L}[/tex]
[tex]dS = \frac{dQ}{T}[/tex]
Since all Carnot cycles imply zero change in entropy, rather than use numbers, I just use [tex]T_R,T_P[/tex] for the temperature of the reservoir and the pot, respectively. When I got stuck, I tried inserting the actual numbers but to no avail. For the reservoir, since its temperature remains constant, and we know how much work it does, its change in entropy is just [tex]\frac{-dQ_1}{T_R}[/tex]. Given the way that the problem is worded, I'm unsure if [tex]dQ_1[/tex] is already negative or not, so I put it here to be safe.
For the pot, its change in heat is [tex]dQ_2[/tex], so its change in entropy becomes:
[tex]\Delta S_P = dQ_2\int_{T_P}^{T_R} \frac{dT}{T} = dQ_2 \ln \frac{T_R}{T_P}[/tex]
We want [tex]\Delta S_P = -\Delta S_R[/tex], so we have
[tex]\frac{dQ_1}{T_R} = dQ_2 \ln \frac{T_R}{T_P}[/tex]
We know that
[tex]\frac{dQ_1}{dQ_2} = \frac{T_R}{T_P}[/tex], so dividing both sides by [tex]dQ_2[/tex], we get
[tex]\frac{1}{T_P} = \ln \frac{T_R}{T_P}[/tex]
But clearly this can't be true, and in fact, substituting in the given numbers show this. Where did I go wrong?
Thanks in advance! :)
[tex]\Delta S_P = dQ_2\int_{T_P}^{T_R} \frac{dT}{T}[/tex]
Should this not be:
[tex]\Delta S_{P} = \int \frac{dQ_{P}}{T_{P}} = \int_{T_P}^{T_R} \frac{mCdT}{T} = mC\ln{\frac{T_R}{T_P}}[/tex]AM
Andrew: Thanks for the help again! I tried it that way, however. If you do it like that, then your entropy expression for the reservoir is stuck with a [tex]dQ_R[/tex] term, which you can get rid of using the [tex]dQ_R/dQ_P = T_R/T_P[/tex] relation, but you ultimately still get the cancellation that I got in my final expression of the problem.
But the dimensions of entropy are Energy/Temperature (J/K). Your integral has dimensions of Energy.
You just have to determine the reversible path and then calculate the change in entropy using that path. For the reversible path (putting a Carnot engine between the reservoir and the pot) the flow of heat to the pot results in the pot gradually increasing its temperature until it reaches 100C. In such a path the change in entropy of the water in the pot is (temp. in K):
[tex]\Delta S_P = mc\ln{\frac{T_R}{T_{Pi}}[/tex]
where m is the mass of the water in the pot and c is the heat capacity of water.
Because work is being done by the heat engine, the magnitude of the heat flow out of the reservoir is GREATER than the magnitude of the heat flow into the pot. But the heat flow out of the reservoir is all at the same temperature T_R, so all you have to do to calculate entropy is find the heat flow and divide by T_R.
AM
So do you mean the heat flow from the reservoir into the pot or just from the reservoir? Because it seems like either way, you just get dQ_R or dQ_P, respectively, which doesn't change anything, unless I'm missing something simple?
The heat flow to the pot is just [itex]mc\Delta T[/itex] where m is mass of the water and c is the specific heat. But this is not the heat flow FROM the reservoir. The heat flow from the 100C reservoir heats the water in the pot AND does work. The amount of work done PLUS the heat flow into the pot gives you the amount of heat flow out of the hot reservoir.
The object is to determine how much heat flows out of that reservoir. The hot reservoir remains at constant temperature, Th. The temperature of the water in the pot, T, increases.
To make the process completely reversible, you need an arbitrarily large number of cycles of the heat engine so that the temperature of the pot is effectively constant during each cycle. Let T be the temperature of the pot as it gradually increases from TP (TPi) to TR (= Th). Express [itex]dS = dQ_h/T_h[/itex] in terms of [itex]dQ_c[/itex] and the temperature of the water in the pot. Then integrate that. You will see that it is the same magnitude as the change (opposite sign) in entropy of the water in the pot.
AM
What is the Carnot engine?
The Carnot engine is a theoretical heat engine that operates on the principles of thermodynamics. It is made up of two isothermal (constant temperature) and two adiabatic (no heat transfer) processes, and is used as a model for the most efficient possible engine.
What is entropy?
Entropy is a measure of the disorder or randomness in a system. In thermodynamics, it is a measure of the amount of energy that cannot be used to do work. In other words, it is the tendency of energy to spread out and become less useful over time.
How do you solve for the entropy of a Carnot engine?
The entropy of a Carnot engine can be calculated using the formula S = Q/T, where S is the entropy, Q is the heat transferred, and T is the absolute temperature. The heat transferred can be found by subtracting the initial and final temperatures of the isothermal processes. You will also need to know the heat capacities of the two reservoirs.
What is the significance of solving for the entropy of a Carnot engine?
Solving for the entropy of a Carnot engine allows us to determine the maximum possible efficiency of an engine operating between two specified temperature reservoirs. It also helps us understand the limitations of real-world engines and how they compare to the theoretical Carnot engine.
What assumptions are made when solving for the entropy of a Carnot engine?
When solving for the entropy of a Carnot engine, we assume that the engine operates in a reversible cycle and that there is no energy transfer through the adiabatic processes. We also assume that the two reservoirs maintain constant temperatures throughout the process and that there is no energy loss due to friction or other factors.
