When is the Cauchy-Schwartz inequality as large as possible?
  • Context: Graduate
  • Thread starter Thread starter pitaly
    Inequality
The Cauchy-Schwartz inequality states that \((\sum_{i=1}^n x_i^2)(\sum_{i=1}^n y_i^2) - (\sum_{i=1}^n x_iy_i)^2 \geq 0\) holds with equality when \(x_i = ay_i\) for some \(a > 0\). The inequality reaches its maximum when the vectors \(\vec{x}\) and \(\vec{y}\) are orthogonal, resulting in \(\vec{x} \cdot \vec{y} = 0\). This condition allows the expression to become arbitrarily large by manipulating the values of \(x_i\) and \(y_i\) while ensuring their differences remain positive.
  • Understanding of the Cauchy-Schwartz inequality
  • Familiarity with vector dot products
  • Knowledge of basic trigonometry, specifically cosine functions
  • Concept of orthogonality in vector spaces
  • Study the implications of the Cauchy-Schwartz inequality in linear algebra
  • Explore vector orthogonality and its applications in geometry
  • Learn about the geometric interpretation of dot products
  • Investigate the relationship between angles and vector magnitudes in higher dimensions
Mathematicians, physics students, and anyone studying linear algebra or vector calculus who seeks to deepen their understanding of inequalities and their geometric interpretations.
pitaly
The Cauchy-Schwartz inequality (\sum_{i=1}^n x_i^2)(\sum_{i=1}^n y_i^2) - (\sum_{i=1}^n x_iy_i)^2 \geq 0 holds with equality (or is as "small" as possible) if there exists an a \gt 0 such that x_i=ay_i for all i=1,...,n.
But when is the inequality as "large" as possible? That is, can we say anything under what conditions (\sum_{i=1}^n x_i^2)(\sum_{i=1}^n y_i^2) - (\sum_{i=1}^n x_iy_i)^2 is as large as possible?
That's easy ! If all xy are negative. Can you interpret that ?
Oops. Major glitch trying to reply too hasty.
First of all welcome to PF :smile: ! And I'll be back soon to post something more useful -- if I don't get corrected sooner by someone more awake ...
Take 2: That's easy ! If all xiyi are zero. Can you interpret that ?
Sorry, I forgot to say that each x_i \gt 0 and y_i \gt 0
I remember Cauchy-Schwartz had something to do with vector products and you look at ##( \vec x + \vec y ) ^2 = \vec x^2 + \vec y ^2 + 2 \vec x \cdot \vec y = \vec x^2 + \vec y ^2 + 2 \,| \vec x | \, |\vec y| \cos \alpha##.
The equals sign in CS is if ##|\cos\alpha| = 1 ## so I have a feeling that what you asked for might be found at ##\cos\alpha= 0 ##.
In post #4 you exclude =0 but then your extreme can be approached as close as desired by letting ##\cos\alpha \rightarrow 0 ##.
If you write the summations as dot products, you can readily see the answer. Let \vec{x} = \langle x_1, x_2, \dotsm, x_n \rangle and \vec{y} = \langle y_1, y_2, \dotsm, y_n \rangle. Then the Cauchy-Schwartz inequality can be restated as:
\underbrace{(\vec{x} \cdot \vec{x})}_{\text{dot product}} \cdot<br /> \underbrace{(\vec{y}\cdot \vec{y} )}_{\text{dot product}} \ge \underbrace{\vec{x} \cdot \vec{y}}_{\text{dot product}} or equivalently \| \vec{x} \|^2 \cdot \| \vec{y} \|^2 \ge \| \vec{x} \| \cdot \| \vec{y} \| \cdot \cos(\theta)
where \theta is the angle between \vec{x} and \vec{y}. Since \vec{x}\cdot \vec{y} = 0 if the two vectors are orthogonal, that's where you will get the largest value.
It can be arbitrarily large. Just take any xi:s and yi:s for which the difference is > 0 and multiply all the xi:s with an arbitrary lange t > 0.
  • · Replies 25 ·
  • · Replies 40 ·
