CD: What Makes a Spacetime Geodesically Complete?
  • Thread starter Thread starter Manicwhale
    Geodesic Proofs
Manicwhale
I'm reading an article (http://arxiv.org/abs/gr-qc/0403075) which proves that a certain spacetime is geodesically complete. It does this by proving that the first derivatives fo all coordinates have finite bounds. My question is why this is enough.
Is it just a simple ODE result? We know that the geodesic equation locally has a solution given an initial "position" and "velocity", by the basic existence result in ODEs. Hence if we show that this "velocity" is bounded everywhere then then the geodesic can extend indefinitely, because the geodesic equation can be solved everywhere. Is this right?
On p. 5, where they say this, they refer to their reference 5, which is a book on ODEs, so it sounds like they are claiming that it is a simple ODE result.
This sounds convincing to me. The general impression I get is that the test they're applying is a very strict one, so it's fairly clear that if a spacetime passes the test, it's geodesically complete. On the other hand, I think there might be many spacetimes that were geodesically complete but would fail this test.
If you had a coordinate singularity, I think your spacetime could be geodesically complete but you wouldn't be able to prove it by this test.
If there is a non-coordinate singularity, but it can't be reached in a finite amount of time, then I believe that is generally considered to be a case where the spacetime is still geodesically complete. I don't know what their test would do in this case -- it might depend on the method they used to prove the limit on the bounds of the derivatives.
You can also get cases like the following. Suppose you take a Minkowski space, described in the usual coordinates, and restrict it to the subset of events with t<0. Then the space would be geodesically incomplete, because every geodesic would terminate at t=0. However, the space can be extended past t=0, so the incompleteness isn't due to a singularity.
Thanks! I think that all sounds right. I'm reassured now.
No it couldn't! Every spacetime with a coordinate singularity is geodesically incomplete. This is definitely becase there are values of coordinates for which the geodesic equations have at least an infinite term. As an example of this, see http://en.wikipedia.org/wiki/Rindler_coordinates" .
AB
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
