Center Frequency and Bandwith of Bandpass Filter?
The discussion focuses on determining the center frequency and bandwidth of a bandpass filter using the transfer function H(s) = s/(s² + 3s + 1). The center frequency is identified as ω = 1 rad/s, while the bandwidth is calculated as the difference between the two frequencies ω1 = 2.355 rad/s and ω2 = 0.425 rad/s, resulting in a bandwidth of 1.93 rad/s. Key calculations involve the magnitude of H, complex conjugates, and the application of the quadratic formula to derive the necessary frequencies.
  • Understanding of bandpass filter concepts
  • Familiarity with transfer functions and complex numbers
  • Knowledge of circuit components such as resistors, capacitors, and inductors
  • Ability to perform calculus operations, particularly differentiation
  • Study the derivation of transfer functions for different filter types
  • Learn about the significance of the complex conjugate in filter analysis
  • Explore the application of the quadratic formula in electrical engineering contexts
  • Investigate methods for calculating bandwidth in various filter designs
Electrical engineers, students studying circuit design, and anyone involved in signal processing or filter design will benefit from this discussion.
Gwozdzilla
Determine the center frequency and bandwidth of the bandpass filter.
center frequency of bandpass filter = ωc occurs when the magnitude of H = 1
H = V0/Vs
Center frequency occurs when Im(Z) = 0
Zc = 1/(jωC) = 1/s
ZL = jωL
ZR = R
I don't know a formula for finding bandwidth.
Zseries = 1 + 1/s
Zll = ((1/s)(1 + 1/s))/(2/s + 1)
Zeq = 1 + Zll
Simplifying gives...
Zeq = (1 + 3s + s2)/(2s + s2)
Vs = IZeq
Vll = IZll
V0 = I2(1Ω)
Vseries = I2Zseries = Vll
V0Zseries = Vll = IZll
V0Zseries = (VsZll)/Zeq
V0/Vseries = Zll/(ZeqZseries)
Plugging in values from above and simplifying gives...
V0/Vseries = s/(s + 3s + 1) = H
s2 = -ω2
How do I find the magnitude of H? What is a bandwidth?
First thing you should do is label the components R1, C1, C2, R2 left to right. Then work with these symbols.
Then: your H(s) can't be right since it has gain = 1/4 at high frequencies whereas the network H(s) must have zero gain there, thanks to C1.
Hello GZ,
Took me a while too to untangle this. In the mean time Rudy chipped in, but here's my 2 cents as well:
It would have been easier for me (and probably for others too) if you would have told us what you mean with the various symbols.
Up to Vseries= ... I agree. Then V0 Zseries=Vll x (1Ω) otherwise the dimensions don't fit. But numerically you're still good.
V0/Vseries = Zll x (1Ω)/(ZeqZseries) is something you could have gotten more straightforward as
V0/V|| = 1Ω / Zseries multiplied with
V||/Vs = Zll / Zeq
The typo that distracted Rudy demonstrates your derivation is a bit complex (too many Z, too many inversions and then inverting again). Never mind.
Magnitude of H follows from ##\sqrt{ H^{\displaystyle ^*} H }## as with all complex numbers.
(At first, LaTeX let me down here, with ##H^{\displaystyle ^*}## I mean the complex conjugate of ##H## )Bandwith is ##| \omega_1 - \omega_2 |## where ##H^2(\omega_{1,2}) = H^2_{max}/2##
So from my value for H = s/(s2 + 3s + 1), I can convert back to using jω:
H = (jω)/(-ω2 + 3jω + 1)
H = (jω)/(3jω + (1-ω2))
The complex conjugate of the denominator is then 3jω - (1-ω2). I can multiply the numerator and denominator by this and simplify to get:
H = ((ω2-1)(jω) - 3ω2)/(-9ω2 -1)
√(H*H) = 1 → H*H = 1
((ω2-1)(jω) - 3ω2)/(-9ω2 -1) = 1
2-1)(jω) - 3ω2 = -9ω2 -1
Simplifying gives the quadratic equation:
(6 + j)ω2 - jω + 1 = 0
The quadratic equation gives the result:
ω = -.0219 -.331j
I don't think I did that right. Did I determine the complex conjugate incorrectly?
So for the bandwidth, am I supposed to find dH/dω = 0, and plug that ω back into find Hmax, then solve Hmax2/2 or am I misunderstanding?
ω = -.0219 -.331j
You never performed HH*. When you multiply numerator & denominator of H(jw) by the cc of the denominator you wind up with the original H(jw), not the cc
You compute |H| = √|H(jw) H*(jw)|, which is the magnitude of H(jw) and is a real number.
You can then set d|H|/dw = 0 to solve for w of |H|. Plug into |H| and you get |Hmax|. Then set |H| = 1/√2 Hmax and solve for w again. This time you get two w. Rest is as BvU stated.
How do I find the complex conjugate of something in the form of (jω)/(3jω + (1-ω2))? I don't see how to simplify it into an x + iy form.
Is the complex conjugate (-jω)/(3jω - (1-ω2))?
If this is the complex conjugate then I get...
√[(jω)/(3jω + (1-ω2))][(-jω)/(3jω - (1-ω2))] = 1
ω4 + 8ω2 + 1 = 0 which only has imaginary roots, so it's probably also wrong.
No need to simplify. Just replace every instance of j by ##-##j
That's the idea. (##d|H|\over d\omega## you mean, of course ... :wink:).
Okay, so when I replace every instance of j by -j, the complex conjugate is (-jω)/(-3jω + (1-ω2)).
[(jω)/(3jω + (1-ω2))][(-jω)/(-3jω + (1-ω2))] = 12
This simplifies to 0 = ω4 + 6ω2 + 1
so ω = ±j(.414) and ω = ±j(2.414)
Is this part correct?
Why are you setting |H|2 = 1?
I thought that a bandpass filter was defined as having its |H(ωc)| = 1. Is this not the case?
Check it out ! You already have an expression for ## |H(\omega)|##
No it isn't. You need to go d|H|/dw = 0, solve for w, replace in |H|.
|H(ω)| = [(jω)/(3jw + (1-ω2))][(-jω)/(-3jw + (1-ω2))]
|H| = ω2/(7ω2 + ω4 + 1)
d|H|/dω = 2ω(7ω2 + ω4 + 1)-12(7ω2 + ω4 + 1)-2(14ω + 4ω3) = 0
Simplifying gives ω = 1. Is this the center frequency?
|H(1)| = 1/9 Is this the bandwidth?
Yes, if you did the math correctly. I did not check it.
No. |H|(1) = max. gain.
I did not check your math but your approach is correct up to then.
Follow what I said in post 5 near the end to get the bandwidth.
|H(ω)| = ω2/(7ω2 + ω4 + 1) = (1/√2)Hmax = 1/(9√2)
Solving for ω gives ω = ±2.355 and ±.425
Bandwidth = B = ω2 - ω1 = 2.78 or 1.93
Is this correct?
Is this correct?
ω cannot be negative, at least not for you now.
Otherwise, looks right if you did the math right.
Check #1: does |H| → 0 as ω → 0? Yes.
Check #2. does |H| → 0 as ω → ∞? Yes.
Check #3: does √(ω1ω2) = ω0 = 1? √[(2.355)(0.425)] = 1. Yes. (This test rests on what I state below in my last sentence. So you most probably got the mid-band and corner frequencies right.
EDIT: But it's not sure. What you can say is that if √(ω1ω2) is not = ωmax then you got something wrong. In other words, it's a necessity but not a sufficiency test.)
So, H is a bandpass, since gain is zero at DC (ω=0) and at arbitrarily high frequencies, and gain > 0 somewhere inbetween.
But you don't have the right answer for bandwidth. Bandwidth is the width of the passband around the peak, with rolloff frequencies at gain = |Hmax|/√2 on either side of the max. frequency ω0. If you're using log paper (for the x axis), the two points w1 and w2 are equidistant from w0. ω0 is the geometric mean between ω1 and ω2. So take another shot at bandwidth.
If I know that ω1 and ω2 are correct by calculating that √ω1ω2 = 1, and I know that I should take the positive values of ω1,2, then why isn't the bandwidth = |ω12| = |.425-2.355| = |-1.93| = 1.93?
I said ω is always > 0 but you still got the same right answer: bandwidth = 2.355 - 0.425 = 1.93 rad/s.
BTW look again at my post #17. I edited it a bit.
  • · Replies 20 ·
15K
