What is the Center and Radius of a Circle?
The discussion focuses on determining the center and radius of a circle, as well as finding the y-coordinates of intersection points with the y-axis. The equation used is \(x^2 + (y + 1)^2 = 20\), confirming that if the circle intersects the y-axis, the x-coordinate is 0. The y-coordinates of intersection points are calculated as \(y = -1 \pm 2\sqrt{5}\), resulting in the points \((0, -1 + 2\sqrt{5})\) and \((0, -1 - 2\sqrt{5})\).
  • Understanding of circle equations in the form \((x-h)^2 + (y-k)^2 = r^2
  • Knowledge of algebraic manipulation and solving equations
  • Familiarity with square roots and their properties
  • Basic coordinate geometry concepts
  • Learn how to derive the center and radius from the standard form of a circle equation
  • Study the implications of circle intersections with coordinate axes
  • Explore the use of the quadratic formula in solving for y-coordinates
  • Investigate the geometric interpretations of circle equations and their graphs
Students, educators, and anyone interested in mastering the concepts of circle geometry and algebraic equations related to conic sections.
mathdad
A. Determine the center and radius of circle.
B. Also, find the y-coordinates of the points (if any) where the circle intersects the y-axis.
Mathematics news on Phys.org
If the circle were to intersect the y-axis, then what would x be?
If the circle intersects the y-axis, the value of x is 0. True?
No. If the circle intersects the y-axis, the value of x is 0 at the point(s) of intersection.
We must be absolutely clear.
Re: Center & Radius of Circle
How is part B found?
- - - Updated - - -
Is my work for part A correct?
Yes, part A is correct.
Part B asks you to find the coordinates of the points where the circle intersects the y-axis. Joppy led you to the conclusion that those points must have x= 0. Now put x= 0 in the equation of the circle to determine what y is.
Part B
Let x = 0
(0)^2 + (y + 1)^2 = 20
(y + 1)^2 = 20
sqrt{(y + 1)^2} = sqrt{20}
y + 1 = 2•sqrt{5}
y = 2•sqrt{5} - 1
The y-coordinate is 2•sqrt{5} - 1.
Yes?
Is one the points of intersection for the circle
(0, 2•sqrt{5}-1)?
At the point:
$$(y+1)^2=20$$
Your next step should be:
$$y+1=\pm\sqrt{20}=\pm2\sqrt{5}$$
Hence:
$$y=-1\pm2\sqrt{5}$$
And so the points of intersection of the given circle and the $y$-axis are:
$$\left(0,-1+2\sqrt{5}\right),\,\left(0,-1-2\sqrt{5}\right)$$
We should be able to convince ourselves that given the circle:
$$(x-h)^2+(y-k)^2=r^2$$
We then know these points are on the circle:
$$(h+r,k),\,(h-r,k),\,(h,k+r),\,(h,k-r)$$
Cool notes. Check your PM.
  • · Replies 16 ·
