Centrifugal Force load caused from propeller rotation
The discussion focuses on calculating the centrifugal force generated by two propeller blades rotating at 2000 RPM, with a diameter of 72 inches and each blade weighing 4 lbs. The user intends to mill a Clark-Y profile for the blades, allowing for adjustments in pitch using shims at the hub connection. The force calculation is influenced by the mass distribution from the center to the tip of the blades, although the user believes the cross-section profile remains consistent. There is a consideration of safety margins in the design, particularly regarding the yield strength of the bolted connection due to centrifugal forces. Overall, the conversation emphasizes the importance of understanding the forces at play in propeller design for effective performance.
hovercraft57
Is anyone interested in telling me the force created from 2 propeller blades rotating 2000 rpm.The total diameter of the prop is 72 inches and the weight of 1 blade is 4 lbs.
Reason for the question is I want to mill a clark-y profile the length of the blade less ,4 inches for a bolted connection to the hub. The milled bar with the profile is to get twisted after milling to get the pitch.Using shims at the hub blade connection to increase/decrease pitch angle for final setting.
I'm going with the idea the bolted connection yield strength would be based on the centrifugal force of the rotating blades.
Help would be most appreciated,ED
The force will depend a lot on the mass distribution from the center to the tip. You will have to specify that. Clark Y only tells the cross section profile of the blade at each section. I don't think that matters.
the section of the blade is the same 4 inches from the centre to the tip. The lbs/inch is .1111/1 inch of the aluminum flat bar used for a blade. there are 2 blades. I thought not using the weight /inch of the clark -y section would give a ssafety margin. Thanks ED
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
9K
