Centripetal acceleration on Earth
26 replies · 9K views · last reply
daysrunaway
An object orbits the Earth at a constant speed in a circle of radius 6.38 x 106 m, very close to but not touching the Earth's surface. What is its centripetal acceleration?
a = v2/r = 4[tex]\pi[/tex]2v/T2
v = 2[tex]\pi[/tex]r/T
I plugged in r = 6.38 x 106 m and T = 24.0 h = (24.0 h x 3600 s / 1 h) = 86,400 s into the equation above and found a = 3.37 x 10-2 m/s2. However, I looked up the centripetal acceleration on the Earth's surface and found out it is 0.006 m/s2. I can't understand why my answer is wrong. Can anyone point out the error in my logic?
Thanks!
Try using this formula- 2[tex]\pi[/tex]/[tex]\omega[/tex]
[tex]\omega[/tex]= 360/24*3600
Let me know if you got the answer.
Thanks for the suggestion RoughRoad but I don't really understand how I am supposed to use this equation.
I found that my calculation for the angular velocity (2piR/T) is approximately equal to the wikipedia value for angular velocity, so I really am confused now because I can't see what I'm doing wrong in just squaring that value and dividing by 6.38 x 106.
try using the equation GMm/r^2=mv^2/r
m-mass of satellite
M-mass of earth
r-radius of orbit
v^2/r is the centripetal acceleration
gravitational frce of Earth is utilised for centripetal force
m-mass of satellite
M-mass of earth
r-radius of orbit
You are right. But what about the velocity?
you are asked to find the centripetal acceleration you just have to find the value of v^2/r which gives the centripetal acceleration
Oh yeah! How can I be so foolish. Thanks for helping!
I didn't, though, and that's the source of my confusion. I know I have the right value for v but when I plug it into v^2/r, I get 3.37 x 10^-2 m/s^2. This answer is not equal to the answer I found for the actual acceleration, which is 0.006 m/s^2. My question is why is my answer different from the real value?
velocity in dis orbit must b approximately equal to 7.9*10^3m/s
I don't understand why that is, especially since Wikipedia says it is 451 m/s
en.wikipedia.org/wiki/Earth
it wud b easy if u jus show me dat particular part from d article
It's on the sidebar, under "Physical Characteristics".
it is equatorial rotation velocity of Earth while that mentioned here is the velocity of a satellite of Earth in an orbit very close to it both r different
The centripetal acceleration must balance out the acceleration due to gravity (it is essentially at ground level, so 9.8 m/s^2).
*Force of gravity = mg
*Centripetal acceleration = a (not v^2/r, because you are solving for this total value, not any sub-values within a)
The centripetal acceleration when traveling in a constant circular orbit at ground level on Earth should be equal to gravity, or 9.8. You don't necessarily need velocity, radius, mass, time, etc.
Try this-
Centripetal acceleration= [tex]\omega[/tex]^2*r= (2[tex]\pi[/tex]/T)*r
RoughRoad said:
Try this-
but the problem is that the period is unknown, i think
The body moves with a constant speed, so it's T should be 24*3600. I may be wrong though.
