Centripetal acceleration on Earth
26 replies · 8K views
daysrunaway
An object orbits the Earth at a constant speed in a circle of radius 6.38 x 106 m, very close to but not touching the Earth's surface. What is its centripetal acceleration?
a = v2/r = 4[tex]\pi[/tex]2v/T2
v = 2[tex]\pi[/tex]r/T
I plugged in r = 6.38 x 106 m and T = 24.0 h = (24.0 h x 3600 s / 1 h) = 86,400 s into the equation above and found a = 3.37 x 10-2 m/s2. However, I looked up the centripetal acceleration on the Earth's surface and found out it is 0.006 m/s2. I can't understand why my answer is wrong. Can anyone point out the error in my logic?
Thanks!
Try using this formula- 2[tex]\pi[/tex]/[tex]\omega[/tex]
[tex]\omega[/tex]= 360/24*3600
Let me know if you got the answer.
Thanks for the suggestion RoughRoad but I don't really understand how I am supposed to use this equation.
I found that my calculation for the angular velocity (2piR/T) is approximately equal to the wikipedia value for angular velocity, so I really am confused now because I can't see what I'm doing wrong in just squaring that value and dividing by 6.38 x 106.
Is the mass of the satellite given?
try using the equation GMm/r^2=mv^2/r
m-mass of satellite
M-mass of earth
r-radius of orbit
v^2/r is the centripetal acceleration
gravitational frce of Earth is utilised for centripetal force
m-mass of satellite
M-mass of earth
r-radius of orbit
You are right. But what about the velocity?
you are asked to find the centripetal acceleration you just have to find the value of v^2/r which gives the centripetal acceleration
Oh yeah! How can I be so foolish. Thanks for helping!
hope you got the answer
And reply to my visitor msg pls
I didn't, though, and that's the source of my confusion. I know I have the right value for v but when I plug it into v^2/r, I get 3.37 x 10^-2 m/s^2. This answer is not equal to the answer I found for the actual acceleration, which is 0.006 m/s^2. My question is why is my answer different from the real value?
what is the value of v?
there is some error in the velocity value
we get acceleration value almost equal to g
velocity in dis orbit must b approximately equal to 7.9*10^3m/s
I don't understand why that is, especially since Wikipedia says it is 451 m/s
en.wikipedia.org/wiki/Earth
it wud b easy if u jus show me dat particular part from d article
It's on the sidebar, under "Physical Characteristics".
it is equatorial rotation velocity of Earth while that mentioned here is the velocity of a satellite of Earth in an orbit very close to it both r different
The centripetal acceleration must balance out the acceleration due to gravity (it is essentially at ground level, so 9.8 m/s^2).
*Force of gravity = mg
*Centripetal acceleration = a (not v^2/r, because you are solving for this total value, not any sub-values within a)
The centripetal acceleration when traveling in a constant circular orbit at ground level on Earth should be equal to gravity, or 9.8. You don't necessarily need velocity, radius, mass, time, etc.
Try this-
Centripetal acceleration= [tex]\omega[/tex]^2*r= (2[tex]\pi[/tex]/T)*r
RoughRoad said:
Try this-
but the problem is that the period is unknown, i think
The body moves with a constant speed, so it's T should be 24*3600. I may be wrong though.
