Centripetal force for off-centered cylinders rolling down a curve
12 replies · 2K views
caesium
Let's say we have a cylinder of radius r with non-uniform density, resulting in a center of mass shifted away from center of geometry. Let's assume that this center of mass mid-way between center and circumference. So, r_cm = r/2.
Now, let's say this cylinder is rolling down on a curved path of radius R + r. Assume no slip condition.
What is the centripetal force on this cylinder? Does it have "two centripetal forces", from which we find a resultant?
There are no equations here.
My initial attempt: Total Centripetal force on the cylinder would be given by $$\textbf{F}_{net} = mR\omega^2 \textbf{e}_1+mr_{cm}\omega^2 \textbf{e}_2$$ where the vectors e_1 and e_2 have magnitude 1 and point radially outwards (and continuously changing as the cylinder rolls down) as marked in the sketch below. Please advise. Thank you.
wrobel said:
and to which point of the cylinder is this force applied? and why?
As I wrote, given the velocity and the trajectory, it is better to start with the definition of centripetal acceleration. Multiplying that by the mass gives the centripetal force.
Let us have an inertial coordinate frame. For the cylinder I want to write the angular momentum equation about the origin of this frame. And how should I include the torque of the centripetal force into this equation? If it is force indeed, I must put its torque into the angular momentum equation
By definition, centripetal acceleration is that component of linear acceleration which is orthogonal to the velocity.
In principle, we can find the velocity and acceleration of the mass centre. But there is insufficient information here since we do not know the moment of inertia.
