Undergrad Solve Chain Rule Confusion with Diff. Eq. | Help
The discussion focuses on the application of the chain rule in the context of differential equations, specifically regarding the second derivative. The confusion arises from the notation used in the equation where y' = z, leading to y'' = z(dz/dy) = z'. Participants clarify that y'' should be expressed as z(dz/dy) and emphasize the importance of proper differentiation notation. The conversation highlights the necessity of understanding the relationship between variables and their derivatives in kinematics and differential equations.
  • Understanding of differential equations and their derivatives
  • Familiarity with the chain rule in calculus
  • Basic knowledge of kinematics and its equations
  • Proficiency in mathematical notation and differentiation techniques
  • Study the application of the chain rule in differential equations
  • Learn about the relationship between velocity and acceleration in kinematics
  • Review differentiation techniques for functions of multiple variables
  • Explore common notational conventions in calculus to avoid confusion
Students of calculus, mathematicians, and anyone studying differential equations or kinematics will benefit from this discussion, particularly those seeking clarity on the chain rule and its applications.
karenara
while solving differential equations, I got a bit confused with chain rule problem.
The solution says below
yprime = z
then
y double prime = z (dz/dy) = z prime
but I don't understand why the differentiation of z is in that form.
Please help...
If y' = z then, by the concept of equality and the definition of the second derivative, y'' = z'. The chain rule has nothing to do with this.
In kinematics, where v = \frac{ds}{dt} and a = \frac{dv}{dt} = \frac{d^2 s}{dt^2}, then the chain rule gives <br /> a = \frac{dv}{dt} = \frac{dv}{ds} \frac{ds}{dt} = v \frac{dv}{ds}, a change of variable which is occasionally useful, particularly if a is given in terms of s.
If ##y'=z## denote the independent variable with ##x## then ##y'(x)=z(x)## and ## y''(x)=\frac{d}{dx} y'(x)=\frac{d}{dx}z(x)=z'(x)##
sorry but, that's not what I'm asking..
I mean the second term in the equation.
karenara said:
sorry but, that's what not I'm asking..
Are you asking about the part in the middle in the last equation?
yprime = z
then
This doesn't make sense to me. The tacit assumption here seems to be that you're differentiating with respect to z, with z being the independent variable. What you have in the middle should be ##\frac d {dy}z##, which is different from ##z(\frac{dz}{dy})##.
It would help if you showed us the actual problem.
yes there is a problem with the notations as @Mark44 said, are you sure that the middle term is ##z\left(\frac{dz}{dy}\right)## ?
i definitely agree with what you guys said and that was the reason why I was asking this here. Then do you think it's just a typo? I thought i mistook something.
I found out why! It is in fact, chain rule.
if we differentiate left and right side by t
dz/dt = dz/dy X dy/dt
, dy/dt=y'=z...
Likes Ssnow
ok it is ##y''=\frac{d}{dx}y'=\frac{d}{dx}z=\frac{dy}{dx}\frac{dz}{dy}=z\frac{dz}{dy}##
Likes karenara
nice timing! lol we almost uploaded the response at the same time! anyway thanks a lot for sparing your time for my question! :)
nothing! yes simultaneously. I was also in doubt at the beginning, this the miracle of calculations ...
