Change in direction and acceleration
Change in direction of a moving body results in acceleration due to the alteration in its velocity vector, which encompasses both magnitude and direction. Acceleration is defined as the time rate of change of velocity, meaning that any change in direction signifies a change in velocity, thus indicating acceleration. While acceleration can be described as positive or negative based on the increase or decrease of speed, it is fundamentally a vector quantity with both magnitude and direction. The discussion emphasizes that variable velocity, rather than mere change in direction, is what leads to acceleration. Understanding vector subtraction is crucial for calculating acceleration when a body changes its direction, particularly in uniform circular motion.
quantizedzeus
Why and how does Change in direction of a moving body accelerate it?
What's the definition of acceleration?
Displacement, velocity and acceleration are vector quantities. A vector quantity not only consists of magnitude (a real number/scalar) but it also consists of direction.
Recall that the definition of acceleration is time rate of change of velocity vector. We care both the magnitude and direction.
You may have a look on the topic of uniform circular motion.
It may be mentioned that while the velocity also determines the direction of body , acceleration does not determine the direction of body . Acceleration is a vector quantity because it can be negative . This is because a body can accelerate or retard . Positive and negative sign in acceleration just tell that whether speed is increasing (velocity for particular) or decreasing . For eg. -5m/s2 tell that a body retards by 5m/s velocity .
Change in direction does not bring acceleration . Change in direction means variable velocity and variable velocity means change in velocity per unit time .
Here variable velocity is bringing acceleration . Change in direction is cause of variable velocity.
http://en.wikipedia.org/wiki/Uniform_circular_motion"
Orhttp://www.physicsclassroom.com/mmedia/circmot/ucm.cfm"
Also see scalar and vector quantities.
Vector quantity : Direction + Magnitude and; +ve and -ve. Eg. Displacement , acceleration , velocity etc .
Scalar quantity :Only Magnitude ;and only +ve . Eg. Distance , speed , mass etc .
Sankalpmittal is not using the term 'acceleration' as physicists use it.
Acceleration is defined as rate of change of velocity. When a body changes its direction it changes its velocity, so it has an acceleration This is not just playing with words: we can even calculate the magnitude of a body's acceleration when it goes in a circle at constant speed.
Strictly, acceleration cannot be positive or negative. It is a vector quantity and has magnitude and direction. Informally, we may talk of accelerations being positive or negative, but we're really talking about the component of acceleration in a chosen direction. The same remark applies to velocities and displacements, indeed to all vectors.
Quantizedzeus... To go a step further, do you know how to subtract vectors? It's the essential skill needed in order to find the acceleration when a body changes direction. You consider a time interval \deltat. You find the change in velocity \deltav during \deltat thus:
\deltav = vfinal - vinitial.
The subtraction is, of course, a vector subtraction.
You then divide \deltav by \deltat to get the mean acceleration during \deltat. Finally you find the limit to which this converges as \deltat approaches zero, to get the instantaneous acceleration.
The simplest example, and by far the most important case, is a body moving in a circle at constant speed. It is dealt with in almost any standard mechanics text.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 21 ·
9K
  • · Replies 18 ·
