Change in entropy as gas expands?
The discussion focuses on the change in entropy during the expansion of an ideal gas under isothermal conditions. Participants clarify that while volume increases and pressure decreases, temperature remains constant, leading to an increase in entropy. The key equations used include the ideal gas law (Pv = nRT), the first law of thermodynamics (U = Q - W), and the entropy change formula (dS = dQ/T + σ). The correct approach to solving the problem involves determining a reversible path for the gas expansion and applying the first law to find the change in entropy accurately.
  • Understanding of the ideal gas law (Pv = nRT)
  • Knowledge of the first law of thermodynamics (U = Q - W)
  • Familiarity with entropy concepts and calculations (dS = dQ/T)
  • Ability to analyze reversible processes in thermodynamics
  • Study isothermal processes in thermodynamics
  • Learn about reversible and irreversible paths in gas expansions
  • Explore the implications of the first law of thermodynamics on internal energy
  • Investigate entropy calculations for different thermodynamic processes
This discussion is beneficial for physics students, particularly those studying thermodynamics, as well as educators and anyone preparing for exams involving gas laws and entropy calculations.
alexia29
http://img846.imageshack.us/img846/5678/problemem.jpg
Pv= nRT
U = Q-W
dS = dQ/T (entropy transferred) + σ (entropy created)
Part A.
Assuming that as the gas expands Volume increases and Pressure decreases, thus the Temperature will stay constant.
Part B.
Entropy will increase as the gas expands. Assuming the system is isolated, there will be no entropy transferred in or out.
For entropy created: Because T is constant internal energy U will stay constant, which means that Q = -W = -dPV so dS = -dPV. But the pressure in the problem is not given so I am stuck.
So I was wondering, are my assumptions correct?
  • V and P change but T stays the same
  • no entropy is transferred because the system is isolated
How do I go about solving part b?
Any help please?
alexia29 said:
Pv= nRT
U = Q-W
Part A.
Your explanation is not correct. In an adiabatic reversible expansion pressure decreases and volume increases but temperature also decreases.
Apply the first law. Is the process adiabatic (Q = 0)? Does the gas do any work in this process? Why/why not? What does that tell you about the change in internal energy?
Part B.
Change in Entropy is the integral of dQ/T over a reversible path between the beginning and end states. In order to determine that change you have to first determine a reversible path between the two states. Can you think of such a reversible path? (hint: it is not adiabatic).
AM
Thank you for your help. I understand part A now, and I think I can solve Part B also.
Could you check if my answer for part B makes sense?
TdS =INT(dU + PdV)
dS = P/T * INT(dV)
dS = nR/V * INT (dV)
S = nR/V * ln (V2/V1)
S = (0.001 moles * 8.314)/(20cm^3 * (1 m^3/1000000cm^3)) * ln (80/20)
S = 576 J/K
So the overall entropy is increasing, because entropy is being produced by the gas expansion. Entropy is not being transferred in or out of the system.
Can anyone help? I have a test tomorrow and the professor said the concepts of this question are going to be in it and I am concerned I am still not understanding entropy.
TdS =INT(dU + PdV)
dS = P/T * INT(dV)
S = 576 J/K
Here is how you solve B:
1. determine a reversible path between the beginning and end states. The temperature is constant. The volume increases from 20 to 100 ml. So a reversible path between initial and final states would be an isothermal quasi-static expansion from 20 ml to 100 ml. Such an expansion would do work so there would have to be heat flow into the gas.
2. Apply the first law:
Q = ΔU + ∫PdV (what is ΔU if T is constant?)
3. ΔS = Q/T. Determine ΔS.
AM
