Change in Kinetic energy / Momentum
To calculate the change in kinetic energy and momentum for a truck turning from north to east, the truck's speeds must be converted to meters per second. The change in momentum requires treating the velocities as vectors, necessitating the use of components for accurate calculations. The initial and final momenta must be subtracted vectorially, not numerically, to determine the correct magnitude and direction of the change in momentum. Using arctan is essential for finding the direction of the momentum change. Following these steps leads to the correct solution.
R.H.2010
A 2800 kg truck traveling north at 35 km/h turns east and accelerates to 55 km/h.
What is the change in the truck's kinetic energy?
What is the magnitude of the change in the linear momentum of the truck?
What is the direction of the change in the linear momentum of the truck?
I know the change in something is Final minus initial, and i have been using momentum=mass times velocity , Kinetic Energy = half mass times velosity's square, but I'm still not getting the right answer. Any suggestions please? Thank you.
Show what you've done so we can see where you went wrong.
Hints: Make sure you convert the speeds to standard units, like m/s. Also, remember that momentum is a vector; direction matters.
a) I finally got this part after paying attention to units.
b) (2800)X(550/36) - (2800)X(350/36)
reading your hints: what do you mean to deal with velocities as vectors in momentum equations?
c) I know I will have to use arctan, but it looks like I'm missing the vectors part that i will need to do c.
That equation is not valid since the initial and final momenta are in different directions. You have to use components and subtract the momenta as vectors, not just numbers.
c) I know I will have to use arctan, but it looks like i'm missing the vectors part that i will need to do c.
Exactly. You need the vector stuff to do parts b and c.
Do this. Call east the +x axis and north the +y axis. Now find the x & y components of the initial and final momenta. Then you can subtract them as vectors and find the magnitude and direction of the change in momentum.
It worked. Thank you very much.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
