Change of relative permittivity of liquid and solid water
The relative permittivity of liquid water is approximately ε_r = 78.0ε_0, while for ice, it is ε_r = 4.0ε_0. This indicates that ice is about 20 times less polarizable than liquid water, as confirmed by the discussion participants. The measurements of these permittivities must be conducted at the same frequency, as the permittivity of water decreases significantly at high frequencies. The distinction between free space and vacuum is also clarified, emphasizing that free space is a more precise term in classical electromagnetism.
  • Understanding of relative permittivity and polarization
  • Familiarity with dielectric constants and their measurement
  • Knowledge of electric fields and dipole moments
  • Basic principles of electromagnetism
  • Research methods for measuring dielectric constants at different frequencies
  • Explore the impact of frequency on the relative permittivity of materials
  • Study the relationship between polarization density and electric fields
  • Investigate the differences between free space and vacuum in electromagnetism
Students and professionals in physics, materials science, and electrical engineering who are interested in the properties of polarizable materials and their applications in electromagnetism.
mzh
Dear Physics Forum Users
Commonly, the relative permittivity of liquid water is reported to be \epsilon_r = 78.0\epsilon_0, \epsilon_0 being the dielectric constant of the vacuum.
For ice (solid water), \epsilon_r = 4 \epsilon_0 (heard it in a talk once).
Is it correct to interpret the different values in this way that ice is around 20 times less polarizable than liquid water? Which intuitively would make sense.
Thanks for comments.
How would you measure "polarizableness"?
\epsilon_0 would be the permittivity of free space - "the dielectric constant of the vacuum" would be 1. This is important in relation to above since you may want to consider a substance more polarizable in proportion to the magnitude of the polarization density for a given applied electric field ... the polarization density of a vacuum is zero.
Thanks for your comment, however I don't understand it:
What is the difference between free space and vacuum formally?
Do you agree to the statement that polarization arises from the response of a polarizable material to an electric field, i.e. the dipole moments of the material (built-in or induced) align with the field which creates a new, opposing field, which partially cancels the applied field within the material, albeit not completely (except for within metals).
How then are the different relative permittivities \epsilon_r = 4.0 for ice and \epsilon_r = 78 for water to be interpreted?
Before you do this you should make sure that the two values are measured at the same frequency. For your case, I suspect that they are not.
The value of about 80 is the relative permittivity of water in DC or static fields. It decreases significantly at high frequencies.
The value of about 4 (for ice) may be the one measured in the microwave range, like in this paper (for example):
http://eis.bris.ac.uk/~glhmm/pdfs/WestJEEG07.pdf
http://en.wikipedia.org/wiki/Vacuum
"free space" is less ambiguous.
In classical electromagnetism, "the vacuum of free space" is distinct from just any old vacuum.
However that wasn't the distinction I was going for.
Yes.
Consider:
If I have a material with relative permittivity 20, does it make sense to say that this material is 20x more polarizable than a vacuum (relative permittivity of 1)?
Simon Bridge said:
Consider:
you're saying it does not make sense, because the vacuum is not polarizable..
why do i need to measure the dielectric constant of ice depending on frequency? can I not just insert a block of ice between two electrodes and apply a potential to one side?
From C = \epsilon_r \epsilon_0 \frac{A}{d} and C=Q/U, can I not get \epsilon_r, simply once I know U and Q?
Given such an experiment, I place a piece of ice and a volume of water in the capacitor and measure the relative constant of dielectricity for both, classically, what do the two different values tell me about the material?
  • · Replies 16 ·
52K
