Change variable to solve equation
14 replies · 3K views · last reply
evinda
MHB
Hello! (Wave)
I want to solve the equation $xu_t+uu_x=0$ with $u(x,0)=x$. There is a hint to change variables $x \mapsto x^2$.
I have tried the following.
Let $x=y^2$.
Then $u_x=\frac{du}{dy} \frac{dy}{dx}+\frac{du}{dt} \frac{dt}{dx}=u_y \frac{1}{\frac{dx}{dy}}=\frac{1}{2y} u_y$.
Thus, $xu_t+uu_x=0 \Leftrightarrow y^2 u_t+\frac{1}{2y}uu_y=0$. But the latter doesn't help us to use the method of my post [m]Solve equation[/m].
So do we have to make an other change of variables? (Thinking)
Hey evinda! (Smile)
Suppose we do not use the hint?
We can divide the ewuation by x to make it easier can't we? (Wondering)
I like Serena said:
Hey evinda! (Smile)
Then we have that $u_t+\frac{u}{x} u_x=0$.
$\frac{dx}{dt}=\frac{u}{x}$
$\frac{d}{dt}u(x(t),t)=0$.
Thus, $u(x(t),t)=c$.
The characteristic line that passes through the points $(x,t)$ and $(x_0,0)$ has slope
$\frac{x-x_0}{t-0}=\frac{dx}{dt}=\frac{u}{x}=\frac{x_0}{x}$$x-x_0=t \frac{x_0}{x} \Rightarrow x_0 \left( \frac{t}{x}+1\right)=x \Rightarrow x_0=\frac{x^2}{t+x}$.
So $u(x,t)=\frac{x^2}{t+x}$.
Is everything right?
This time it's not a line is it?
After all, $\d xt$ isn't constant although $u$ is.
Shouln't we solve $\d xt=\frac ux$, and then make sure that it satisfies the boundary condition? (Wondering)
So we substitute here $\d xt=\frac ux$ that $u(x(t),t)=x_0$ ?
If so, then is it as follows?
$$\frac{dx}{dt}=\frac{u}{x} \Rightarrow \frac{dx}{dt}=\frac{x_0}{x} \Rightarrow xdx=x_0 dt \Rightarrow \frac{x^2}{2}=x_0 t+c \Rightarrow x^2=2x_0 t+C \Rightarrow 2x_0 t=x^2-C \Rightarrow x_0=\frac{x^2-C}{2t}$$
Thus, $u(x,t)=\frac{x^2-C}{2t}$.
We have that for $t=0$, $u(x,0)=x$. But can that hold? Is it maybe as follows?
Since $\frac{1}{2t} \to \infty$ as $t \to 0$, it has to hold $C=x_0^2$. (Thinking)
Yes.
It's a bit clearer if we substitute $t=0$ and $x=x_0$ in the earlier expression $2x_0 t=x^2-C$. (Mmm)
I like Serena said:
Yes.
Ok, so then we get that $x_0^2+2 x_0 t-x^2=0$.
$x_0=-t \pm \sqrt{t^2+x^2}$.
Thus, $u(x,t)=-t \pm \sqrt{t^2+x^2}$.
Since $u(x,0)=x$, it follows that $u(x,t)=-t+\sqrt{t^2+x^2}$.
Is this right? Also, do we have to check separately the case $x=0$ since we have divided at the initial equation by $x$ ? (Thinking)
Wait! (Wait)
Wouldn't we get that $u(x,0)=|x|$?
That's not correct, is it? (Wondering)
I believe it suffices to observe that $u$ is well-defined for $x=0$. (Wink)
I like Serena said:
Wait! (Wait)
Oh yes, right... So have I done something wrong? (Thinking)
Why does this suffice? And also how do we deduce it?
It's just that when x changes sign, the solution changes sign as well.
We can fix it with;
$$u(x,t)=-t+x\sqrt{1+\frac{t^2}{x^2}}$$
All our functions are continuously differentiable.
Since the solution is valid for $x\ne 0$, it will also be valid for $x=0$ as long as it is defined. (Thinking)
We can fix it with;
Ok.
The limit $\lim_{x \to 0} \left( -t+x\sqrt{1+\frac{t^2}{x^2}}\right)$ does not exist.
What does this mean? (Thinking)
Ah yes. It means my solution is not entirely correct. (Blush)
Btw, that limit does exist, doesn't it? It's $0$.
Either way, we should either additionally define $u(0,t)=0$, or we should make it $u(x,t)=-t+\operatorname{sgn}(x)\sqrt{t^2+x^2}$, where $\operatorname{sgn}$ is the sign function. (Thinking)
We know that the solution is continuous and we have that $\lim_{x \to 0} \left( -t+ x \sqrt{\frac{t^2}{x^2}+1}\right)=0$, so the solution will be
$u(x,t)=\left\{\begin{matrix}
-t+x \sqrt{\frac{t^2}{x^2}+1}, & x \neq 0\\
0,& x=0.
\end{matrix}\right.$
Right?
0,& x=0.
Right?
Yep! (Nod)
I like Serena said:
Yep! (Nod)
Nice... Thank you! (Smile)
