Changing limits of integration
dalarev
[SOLVED] Changing limits of integration
Given:
\int_{y=0}^\pi\int_{x= y}^{\pi}\frac{sinx}{x} dxdy
Change the order of integration and evaluate the double integral.
My professor told me, "This integral cannot be expressed in terms of elementary functions". I'm not exactly sure what that means.
sinx/x has always been a very common problem for differentiation and integration, so I'm confident I can solve this with a simple substitution. I'm trying to figure out, however, what they mean by not being able to be expressed in terms of "elementary functions".
The integral of sin(x)/x can't be done by any solution. It can't be expressed as a sum or product or quotient of any of the functions you see in calculus. Changing the limits to integrate with y first will allow you to actually do the integral.
So I assume representing sinx/x graphically, and then choosing the correct y limits is all their is to this problem? I'm at work, just trying to get a head start on this problem.
f(x,y) = sin(x)/x is a 2d- surface. Graph the limits, not the function. Then reverse the order so that y is a function of the x in the first integral.
Ok, I see it, will mark as solved. Thanks for the help.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
