Changing wavelength while preserving geometry?
The discussion centers on the possibility of changing the wavelength of electromagnetic (EM) waves and electron waves while preserving their geometric properties and coherence. It explores the role of crystals in altering EM wavelengths and questions whether this process maintains the wave's interference patterns. The conversation also delves into the behavior of electron waves, their relationship to EM waves, and whether their wavelength can be adjusted without collapsing their wave nature. Additionally, the effects of radio frequency (RF) waves on electron acceleration and the potential for reflecting electron waves while maintaining coherence are examined. Ultimately, the participants seek clarity on the interactions between wave properties and the preservation of coherence during these processes.
jaketodd
Are there ways to change the wavelength of an EM wave while still preserving all geometry of the wave (for instance, preserving an interference pattern which has, of course, irregular geometry in between the minima and maxima of the wave)? I've heard some crystals can change the wavelength but I'm thinking that perhaps some geometry would be lost due to parts of the wave running into the molecules and/or atoms that the crystal is made of. Would the wavelength change be a coherency-preserving process?
Is an electron wave the same as an EM wave (besides having a higher frequency)? And if no, is there a way to change an electron wave's wavelength while preserving geometry and coherency as described above?
Thank you!
...And, I forgot to ask: Is there a way to measure the amplitude of an electron wave?
In a dielectric, the wavelength, but not the frequency, of an EM wave is changed. Off normal incidence will change the direction (refraction) and cause reflection. The EM wave still retains its coherence. Both the E and the H amplitudes are perpendicular to the direction of propagation. the Poynting vector, P = E x H gives both the direction and the power. The velocity of propagation is also changed : v = c/n.
An electron is not refracted in dielectrics. At high enough energies, it does not slow down in dielectrics (excepting by radiative processes), and can travel "faster than light" in the dielectric, and as a consequence will radiate Cerenkov light. Electrons can be accelerated by RF voltages, from thermionic emission energies, up to about 100,000,000 volts (100 GeV). Current is measured in amps (=6.24151 x 10^18 electrons/sec), and power by volts times amps.
So an electron's eV is dependent on it's speed? And I read somewhere that eV determines wavelength. So if you slowed down an electron wave, it would change the wavelength? Can this be done without collapsing the wave?/Can this be done while preserving coherency? An electron in an atom is thought to be in wave form, right? And it is changing direction (orbiting) because of the attraction to the proton(s). So I'm thinking that with an EM field or something you could change the speed of an electron wave without collapsing it and preserve its' coherency. I am thinking this partly because you said in your reply that an electron "can be accelerated by RF voltages" and I'm thinking by RF you mean radio frequency which is an EM wave. Is all this correct?
Also, is it possible to reflect an electron wave at an angle while preserving coherency throughout the process?
Thank you!
You are right on. Radio frequency waves in traveling wave cavities, usually 1400 to 10,000 MHz, are used to accelerate electrons (roughly 1 eV or electron volt) from thermionic emission (hot) cathodes, and the energy gain can be as much as 25 MeV (million electron volts) per meter. As the electron gains energy, it gains speed, and when it gets close to the speed of light, it starts gaining mass instead.
In the magnetron, the electron energy is a few thousand electron volts (the cathode is biased negative), and the electric field together with the magnetic field (called a crossed field) bend the electron's trajectory into orbits (based on the Lorentz force). The electrons are bunched as they pass the vanes, and in turn they excite resonances in the cavities. There are no free protons in the magnetron tube. It is just vacuum.
To understand the magnetron tube well, you need to study the differential equations of electrons in crossed fields. There are several books on microwave engineering that go into crossed field tubes and magnetron theory in some detail.
Thank you for your reply! To clarify and reiterate unanswered questions:
So the wavelength of an electron depends on speed? Are you affirming that? Does the interaction of the RF waves, to adjust the speed, collapse the electron to a particle or is coherency/wave-nature preserved? And, is it possible to reflect an electron wave so that coherency/wave-nature is preserved throughout the reflection process?
Thank you!
Jake
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 23 ·
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 74 ·
  • · Replies 36 ·
