Char array initialisation problem
  • Thread starter Thread starter GregA
    Array
The discussion centers around the challenges of initializing a char array in C++ when the size is determined at runtime. The user initially attempts to create a char array with a size based on the length of a string read from a file, but encounters an error because static arrays require a size known at compile time. The solution involves using dynamic memory allocation with `new`, allowing for the creation of a char array with a size defined at runtime. It is emphasized that when using char arrays as C-style strings, a null terminator ('\0') must be included, which is why the size is set to `len + 1`. The use of the `c_str()` member function of the string class is recommended for passing strings to functions expecting C-style strings, simplifying the process of handling string data. The user expresses gratitude for the insights, particularly regarding the use of `c_str()` for file operations.
GregA
I'm currently playing around with strings and char arrays and having problems initialising a char array properly. Basically I've got a text file whose length I want to check before putting the contents into a char array
I define my ifstream variable as in_data and a string as str1.
Then opening some small text file on my computer I use getline(in_data, str1)
I then initialise const int strlen = str1.length()
Now if I initialise char instuff[strlen] I get a problem saying I've initialised my array with a variable. Of course if I put a number in there directly I'm fine but surely I've already defined instuff to be constant (whatever value strlen took) and am scratching my head as to why I'm having a problem.
I apologise for the poor variable names (I'm just experimenting at the mo), and for not putting the entire program here (it is on a computer that isn't online)
Can anyone help?
Technology news on Phys.org
have found out that "strlen" isn't something I should be using as a variable :redface:...but using any other variable name such as "len" gives the same problem.
In C++, the size of a static array has to be known at compilation time. If the size isn't known until you actually run the program, you have to allocate the array dynamically:
Code:
char* instuff = new char(len+1);
Remember that char arrays used as C-style strings have to have a null ('\0') at the end. That's why I used len+1. If you're getting the chars one by one from a C++ style string, you need to insert the null yourself.
Why do you need a char array? If you just need to pass it to a function that expects to receive a const char*, you can use the string's c_str() member function:
Code:
foofunc (str1.c_str());
If you really need your own array, you can use c_str() to initialize it:
Code:
strcpy (instuff, str1.c_str());
I think this takes care of the terminating null for you, too.
Code:
Code:
Code:
Hmm...I didn't consider that the size of that variable would only be known after the program has compiled and it toddles off to read my text file...I didn't know about the c_str() member neither!
Thankyou very much for your help :smile:
I most often use c_str() when I want the user to enter the name of a file to open, because open() requires a C-style string:
Code:
ifstream myfile;
string filename;
cout << "Name of input file: ";
cin >> filename;
myfile.open (filename.c_str());
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
  • · Replies 89 ·
  • · Replies 66 ·
17K
  • · Replies 28 ·
