el3orian
- 1
Why is the characteristic of a finite field a prime number?!
The characteristic of a finite field is definitively a prime number. This conclusion arises from the fact that if the characteristic were composite, it would lead to the existence of nontrivial zero-divisors, which contradicts the properties of a field. Specifically, if p = nm (where n and m are both greater than 1), then the equation 0 = 1 + 1 + ... + 1 (p times) implies that either a or b must equal zero, which is not possible if p is minimal. Thus, the characteristic must be prime.
PREREQUISITESMathematicians, students of abstract algebra, and anyone interested in the foundational properties of finite fields and their characteristics.
Hurkyl said:Short (but same) answer: char(F) is clearly not zero. If it were composite, then it's easy to find a nontrivial zero-divisor.
How can a field have a nontrivial zero-divisor?subGiambi said:Would you mind expanding on this explanation a bit? What is the significance of a nontrivial zero-divisor? Thanks!
