Charge distribution on concentric spheres
The discussion revolves around the charge distribution on two thin conducting spherical shells, where the outer shell is charged and the inner shell is earthed. Participants are exploring the implications of grounding the inner shell on its charge and potential.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are questioning the assumption that the charge on the inner shell is zero due to its grounding. There are discussions about the potential at the inner shell and how it relates to the charge distribution. Some participants suggest considering the potential equations involving both shells.
The discussion is active, with participants exploring various interpretations of the problem. There is a back-and-forth regarding the implications of grounding the inner shell and how it affects the charge on both shells. Some guidance has been offered regarding potential equations, but no consensus has been reached.
Participants are grappling with the implications of grounding in the context of electrostatics, particularly how it affects charge distribution and potential. There are references to potential equations and the need to equate the potential of the grounded shell to zero.
Abhimessi10
Two thin conducting spherical shells have radii R1 and R2.Outer shell is charged to q and inner shell earthed.Find charge appearing on both the shells.
Isnt the charge on inner shell 0 and charge on outer shell remains Q as it doesn't involve any connection?
The inner shell is connected to ground so you cannot make the assumption that the charge on it is zero.
Abhimessi10 said:
So how do i approach this problem?
Sorry isn't the inner shell at potential zero as it is connected to the Earth and thus holds 0 charge
If i am wrong please correct me and tell me how to do this?
Picture a capacitor and a battery connected in parallel, and the bottom connection for both is Earth grounded. What is the charge on each plate of the capacitor? :smile:
Still i think its 0 .Sorry i was born dumb.
Forget the inner shell for the moment. If you have a shell radius r with charge q, what is the potential on its surface? What is the potential at the centre of the shell?
KQ/R right?
Abhimessi10 said:
KQ/R right?
Right.
So now put another shell inside that has no charge. How will that change potential at the centre?
haruspex said:
Right.
It will not change?
Abhimessi10 said:
It will not change?
And so cannot become zero.
Do you still think that a grounded sphere placed inside the shell would have no charge?
Ok
But how do i find charges when the inner shell is earthed?
Abhimessi10 said:
Ok
Suppose it has charge q'. What is the potential at the centre now?
KQ'/R1+kQ/R2 ?
Abhimessi10 said:
KQ'/R1+kQ/R2 ?
Right.
And if the inner shell is grounded what can you say about that potential?
haruspex said:
Right.
Equating potential of inner shell to 0?
Yes. So what equation do you get?
Kq'/r1+kq/r2=0?
Abhimessi10 said:
Kq'/r1+kq/r2=0?
Right.
  • · Replies 19 ·
