Charge on 4 capacitors in parallel then series
neshepard
C. What is the charge on each of the four capacitors if switch S is closed? I have the charges if the switch is open, C1 and C2 are 8μC and C3 and C4 are 6μC since charges are same on series.
I know to find Ceq and work backwards, and that voltage in parallel is the same. But what happens to the volatage's and charges in both a series and parallel layout?
C1 and C3 are parallel Ceq=4μF
C2 and C4 are parallel Ceq=6μF
Each parallel group is in series.
Trying to figure how to add on.
  • Circuit schematic with four capacitors C1 (1 µF), C2 (2 µF), C3 (3 µF) and C4 (4 µF), a switch S, and a 12 V battery; C1 and C2 are in parallel on top, C3 and C4 below, all connected to the battery.
Call C1 in parallel with C3 "C13". Similarly "C24" is C2 in parallel with C4.
Now, C13 = 4μF and C24 = 6μF, as you've calculated above.
The first thing to do is determine how the 12V supply voltage will divide over the series combination of C13 and C24.
