Charge-to-Mass Ratio of Pion & Electron: Compare & Calculate Mass
  • Thread starter Thread starter justgroovin
    Mass Ratio
The discussion revolves around the charge-to-mass ratio of pions and electrons, with a specific focus on comparing their masses. The original poster presents a problem involving the He3 atom and seeks to understand the relationship between charge and mass for these particles.
  • Participants explore the charge-to-mass ratio of pions, questioning how it relates to the original poster's calculations and assumptions. There is discussion about the nature of pions as mesons and their charge states. Some participants express confusion regarding the application of the charge-to-mass ratio equation.
The discussion is ongoing, with participants providing insights and clarifications about the nature of pions and the calculations involved. There is recognition of the need for more information to fully address the original poster's questions, and some participants suggest reconsidering the assumptions made about the relationship between the He3 atom and pions.
Participants note that the charge-to-mass ratio for the pion was not provided and is expected to be determined through the original poster's sketch. There is also mention of the confusion surrounding the charge of pions and how it affects the calculations.
justgroovin
1.Sketch a diagram of the atom He3, using the appropriate quarks and leptons.
2 The charge-to-mass ratio of the pion was determined in 1. The charge-to-mass ratio of the electron is 1.76 x 10^11 C/kg.
a) Based on this info, predict which particle has a greater mass- the electron of the pion . Justify your answer by referring to the charge-to-mass ratio.
b) Use the value of the elementary charge (e = 1.6 x 10^-19C) to calculate the mass of the pion in kg. Compare the mass of the pion to the mass of the electron.
q = q/m x m
1. No problems, just stated question to illustrate entire problem
2a) I predict the He3 particle will have more mass- it consists of 2 protons, 1 neutron and 2 electrons
2b) mass of electron = charge/ charge to mass ratio
= (1.6 x 10^(-19) C)/(1.76 x 10^11 C/kg)
= 9.09 x 10-31 kg
It's the pion charge-to-mass ratio I'm having troubles with. Between the quarks and leptons- it is a neutral atom, therefore dividing the charge by the mass is 0
I feel like I've been at this too long, and I'm missing a basic point here.
Please help
There is not enough information to formulate an intelligible reply.
The Pion is not an atom, it is a meson.
Pions can have ±1 elementary charge. That is the charge to mass ratio the question is referring to. This is something you should have, according to the question.
So the pion is a meson of the He3 atom?
Can't pions also have a 0 charge? +1, -1 or 0 charge?
Thank you for your help.
The charge-to-mass ratio was not provided. It was to be determined trhrough my sketch in #1. The sketch shows that the quarks and leptons cancel each other out to leave the meson with a 0 charge
How does sketching a He3 atom provide you with data on a pion?
Consider the following, there are three kinds of pions, [tex]\pi ^ 0, \pi ^{-}, \pi^{+}[/tex]
I figured that since it helped me to see that the quarks and leptons cancel out each other, it shows a 0 charge. Since the ratio is q/m and q = 0 then the ratio = 0.
justgroovin said:
q = q/m x m
How exactly is this equation supposed to help solve the problem?
mass = charge/ charge to mass ratio
is what I got from that equation, and I used this to help me determine the mass of the electron.
I am supposed to compare the mass of pion to the mass of the electron, so I needed to determine the mass of the electron.
This is my final question in my ILC course (other than my unit summary) before I prep for my final. I haven't NOT answered any questions yet, and I could really use some help to understand what I'm just not getting about this one.
Any input would be helpful please.
Thank you
Thank you
A Pion has very little in common with He3, is the problem.
  • · Replies 28 ·
  • · Replies 21 ·
11K
