Why is Bremstrahlung or K-shell emission necessary in an x-ray machine?
In summary: Google "Larmor formula"Classically the rate of radiation emitted in an acceleration varies as the acceleration squared. In the case of a typical X-ray tube the anode cathode distance is a couple of centimeters while the distance it take an electron to decelerate in an anode say of Tungsten is a small fraction of a millimeter.That would be all thanks, you are the best. Just to get all clear, could you explain why is the distance important here? Is it because the desaceleration/aceleration happen faster when distances are short so they have to be bigger? It doesn't matter one happens via bremstrahlung and the other happens for a potential d
AndresPB
28
Good morning all, I was just wondering the following question. When an electron is accelerated it emits electromagnetic radiation, depending on how much it is accelerated the energy varies so the frecuency does and the electromagnetic wave emitted would be of different colors or maybe even x-rays if the velocity is high enough. If this happens inside an x-ray machine, then why is it neccesary for the process of Bremstrahlung to occur? or K-shell emision? Would the electron alone be enough to generate x-rays or it is enough and the other fenomena occur only to generate more of them?
In an X-rays tube depending on the composition of the anode X-rays are mainly the result of Bremsstrahlung production due to the rapid deceleration of the electrons or the emission of characteristic X-rays due to the excitation of the atoms in the anode from the electron beam. Thus a Tungsten anode (Z= 74) produces mostly Bremsstrahlung while an anode of Molybdenum (Z=42) will have a larger percentage of characteristic X-rays.
The acceleration of the electrons due to the potential difference between the anode and cathode is insufficient to produce significant radiation.
Likes AndresPB
Totally awesome thanks, how can i do a fast estimation of why the accelaration due to the potential diference is insufficient?
The acceleration in bremsstrahlung happens within the size of an atom. The acceleration between the electrodes happen within centimeters, the acceleration is about 9 orders of magnitude smaller.
Thanks a lot, could you put the formula?
total radiated power = (2/3)(e2/c3)a2 in the Gaussian unit system.
Where e is the electronic charge
c is the velocity of light
a is the acceleration
Likes AndresPB
Thanks a lot, where can i read about its deduction?
Likes AndresPB
That would be all thanks, you are the best. Just to get all clear, could you explain why is the distance important here? Is it because the desaceleration/aceleration happen faster when distances are short so they have to be bigger? It doesn't matter one happens via bremstrahlung and the other happens for a potential diference?
Right.
You can see the acceleration around an atom as potential difference as well - just with much higher field gradients. Well, quantum-mechanical effects can become relevant there, but let's ignore them for now.
What is charged particle radiation?
Charged particle radiation is a type of energy emitted from atoms or subatomic particles that have an electric charge. These particles can be positively or negatively charged and can travel at high speeds.
What are the sources of charged particle radiation?
Charged particle radiation can come from natural sources such as the sun, radioactive materials in the earth, and cosmic rays from outer space. It can also be produced artificially through medical procedures, nuclear power plants, and particle accelerators.
How does charged particle radiation affect living organisms?
Charged particle radiation can cause damage to living organisms by breaking apart the chemical bonds in cells and DNA. This can lead to mutations, cell death, and potentially cancer. The effects of radiation exposure depend on the type and dose of radiation, as well as the duration of exposure.
How can we protect ourselves from charged particle radiation?
There are various ways to protect ourselves from charged particle radiation, such as limiting exposure time, increasing distance from the source, and using shielding materials. In addition, following safety protocols and regulations for handling radioactive materials can help minimize exposure.
What are the applications of charged particle radiation in science and technology?
Charged particle radiation has various applications in science and technology, including medical imaging and treatment, sterilization of medical equipment, and industrial processes such as food preservation and material analysis. It is also used in research to study the structure and behavior of matter at the atomic and subatomic level.
  • Biology and Medical
  • High Energy, Nuclear, Particle Physics
  • Electromagnetism
  • Quantum Physics
  • Quantum Physics
