Charges on an equilateral triangle
7 replies · 5K views · last reply
4real4sure
Charges Q, Q, and q lie on the corners of an equilateral triangle with sides of length a. Charge q lies on the top corner with Q and Q on the left and right corners.
(a) What is the force on the charge q?
(b) What must q be for E to be zero half-way up the altitudeat P?
F=(1/4πε) * (q1q2/r2)
E = (1/4πε) * (q/r2)
(a) F = qQ / (4πεa2) iy
(b) Eq = q / (4πε (3/16 a2)) iy
and EQ = Q / (4πε (7/16 a2)) iy
I just wanted to know if the attempts are in proportion to the required?
Thanks a lot in advance.
No, that's not quite right.
You are correct that the net force is completely in the [itex]\hat \imath_y[/itex] direction. That is because the [itex]\hat \imath_x[/itex] components of each force from the Q charges cancel.
But the [itex]\hat \imath_y[/itex] force components do not lead to your answer.
Those electric field calculations are not quite right either.
I tried to do it several times based on may understanding but for some reason I am so not able to reach to the solution. Any hint?
Did you begin with a diagram of the triangle, labeling all sides in cluding the altitude?
Equilateral triangle with charge q at the top vertex and charges Q at the two base vertices; sides labeled a, the altitude labeled √3/2 a, and the base segments labeled a/2.
If you calculate the force that one Q exerts upon q along a side a, then what is the y-component of that force? Hint: you can determine the trigonometric functions (sin, cosine) of the angle using an appropriate ratio of sides.
  • Equilateral triangle with a charge q at the apex and charges Q at the two base corners. Sides are labeled a, the altitude is labeled √3/2 a, and the base halves are labeled a/2.
Let's start with the first part (a).
For each charge Q at the bottom, you can find the magnitude of the force from that particular charge on charge q using
[tex]\vec F = \frac{1}{4 \pi \varepsilon_0} \frac{qQ}{r_2} \hat \imath_r.[/tex]
where [itex]\hat \imath_r[/itex] points in the direction from the particular Q to q.
But the [itex]\hat \imath_r[/itex] for one charge is different from the [itex]\hat \imath_r[/itex] of the other charge, because they point in different directions. So you can't just add them simply. For each case, you need to break up [itex]\hat \imath_r[/itex] into its [itex]\hat \imath_x[/itex] and [itex]\hat \imath_y[/itex] components.
That might involve something like
[tex]F_x = F\cos \theta[/tex]
[tex]F_y = F \sin \theta[/tex]
(This relationship is just for example purposes, the particular relationship may depend on the particular problem/particular pair of charges).
Or if you don't want to use trigonometric functions, you can do it using the Pthagorean theorem (which works with this problem). If a is the side of an equilateral triangle, and you vertically bisect the triangle down the middle, forming two isosceles triangles, then the base of each isosceles triangles is a/2. What does Pthagorean theorem tell you about the height of the triangle relative to a?
I tried and I finally reached the solution. Thanks for all your support!
I am working on the second part of this question and don't understand why the (7/16) is to the power of 3/2. Am I just missing something obvious?
In order to be able to comment we'll have to see your work.
