Charges on two small spheres suspended from a thread
The discussion revolves around two small spheres, each with mass and charge, suspended by threads at an angle from the vertical. Participants are exploring the forces acting on the spheres, particularly the balance between gravitational and electrostatic forces.
  • Participants discuss the relationship between gravitational and electrostatic forces, questioning how these forces interact given their directions. There is an exploration of free body diagrams (FBD) to visualize the forces acting on the spheres.
Some participants have offered guidance on the importance of considering all forces acting on the system, while others express uncertainty about the correct approach to finding the charge on the spheres. Multiple interpretations of the forces involved are being explored.
There is a noted difficulty in determining the electrical force without knowing the charge, and participants are grappling with the implications of the forces not acting in the same direction. The problem setup includes constraints such as the angle of the threads and the assumption that the charges on the spheres are equal.
OmegaFury
Two small spheres, each with mass m = 5.0 g and charge q, are suspended from a point by threads of length L = 0.30 m. What is the charge on each sphere if the threads make an angle θ = 20° with the vertical?
F=k|q1q2|/r2
I found the opposite side of one of the triangles to be around 0.10m (0.30mSin(20°)=opp). So the radius between the two charges would be 2 x opposite side length= 0.20m. Without knowing the force between the two charges, I'm at a loss as to how to find the charge on each sphere. I do have an idea: I find it strange to have two spheres floating without coming together due to gravity, so I'm guessing that for this to happen, the electric force may be equal to and in opposition to the gravitational force. Is this the right line of thinking?
Yes, that line of thinking is correct.
Alright. So. I can't use the equation Fg=Gm1m2/r2 since I do not know the position of the spheres relative to the earth. So I set up a coordinate system, of which the origin is in the middle where the two threads meet. Gravity only affects the y-direction, so the x-components are irrelevant. I labeled the two spheres m1 and m2 respectively. I made the y-direction below the origin to be the positive y-direction, therefore the sum of the forces in the y direction is equal to Fym1+Fym2. Fym1=mgsin(20°)=0.05N. Fym2 is equal to the same thing, therefore the sum of the forces in the y-direction is equal to 0.10N. I'm assuming that the charges on both of the spheres are equal, so q1 times q2 is equal to q2. Rearranging the electric force equation, I got q=sqrt(Fr2/K). q=sqrt(0.10N x (0.20m)2/k)= 6.67 x 10-7C. Unfortunately, this is not the correct answer.
how can electrostatic force oppose gravitational force when both are at right angles. Further electrostatic force is an internal force for the 'system of two charged spheres' so it cannot effect the state of 'system'. You are missing one more force.
I was wondering about that, direction-wise. The electrical force is only affecting the x-direction... If there is a missing force, I do not know of what it may be.
Can you show me the FBD. Always draw FBD(free body diagram) when you are solvimg mechanics questions
Well, it's not necessarily a mechanics question. I just thought a mechanics approach could solve the problem. The problem here is that I have to find the charge on the two spheres, even though I don't even know the electrical force between them. If Fg-Fe does not equal zero (Fg=Fe), as they don't work in the same direction, then I can't use the electrical force equation to solve for q. That makes a FBD kind of useless, doesn't it?
I've attempted this but I'm not sure I'm right. Do you happen to have the correct answer?
Yes, I do. It's 2.9 x 10-7C
Ok didn't get it 1st go, but got it now.
So tell me...
What force/s act in the y direction?
What force/s act in the x direction?
What is the angle created by this triangle?
TRY AN FBD. IT WILL HELP GARGANTUANALLY.
  • · Replies 19 ·
  • · Replies 50 ·
14K
