[CHECK] tension problem a little help
  • Thread starter Thread starter warmfire540
    Tension
The discussion revolves around calculating the tension in two strings supporting a 2.0 kg ball whirling in a horizontal circle. The minimum speed for the lower string to be taut is determined to be 5.66 m/s, while the tension in the upper string is calculated to be 22.6 N using vertical force components. The tension in the lower string is found to be 6.4 N after considering both the vertical and horizontal components of the forces acting on the ball. Participants emphasize the importance of drawing clear diagrams and labeling forces to avoid confusion. The thread concludes with the original poster confirming their final calculations and expressing gratitude for the assistance received.
warmfire540
[CHECK] tension problem! a little help
A 2.0 kg ball is attached to a vertical post with two strings, one 2.0 m long and the other 1.0 m long as shown in the figure. If the ball is set whirling in a horizontal circle, what is the minimum speed necessary for the lower string to be taught? If the ball has a constant speed of 6 ms-1, find the tension on each string.
| \ -2.0m
|----0 -2.0kg
| ^1m
For the first part, figured that the 2m string has two components of tension Tsin60 and Tcos60.
Tsin60=mg=19.6
Tcos60=mv^2/r=2v^2
tan60=19.6/2v^2
v=5.66 m/s
is that right? I calculated the angle that the 2m string made w/ the x-axis and went from there...
Now..for the second part..
i figured that the tension in the 1m string is the centripital force which is:
T=mv^2/r=2*36/1= 72N
Now for the second string..what would the tension be?
i'm guessing i have to use the Tsin60 and the Tcos60
Tsin60=19.6N
Tcos60=72N
T=sqrt(19.6^2+72^2)
T=74.6N
I hope this is right, i did all the work, I'm just looking for confirmation please
Hi warmfire540! :smile:
How far apart are the ends of the two strings? :confused:
They are 1.73m apart using pythagorean's theorem
I asked because your diagram doesn't look like that!
warmfire540 said:
tan60=19.6/2v^2
v=5.66 m/s
That's fine … except you forgot to take the square-root. :rolleyes:
i figured that the tension in the 1m string is the centripital force …
Nooo … the centripetal acceleration is matched by the horizontal components of all the forces … in this case, the tensions in both strings.
Try again! :smile:
Hmm, i got v^2=19.6/2tan60
v^2=5.66
v=2.38m/s
Try again! :smile:
So, i don't understand then what the centripital force would be, how does the 2m string interfere with this? are my tensions wrong for part 2? Do i have part 1 right at least?
THANKS!
-warmfire540
Yes, part 1 is right now! :smile:
For part 2, do the vertical components first … that gives you the tension in the top string, doesn't it?
Then do the horizontal components. :smile:
Well..the vertical component for the 2m string is:
Tsin60
for the 1m string
None
The horizontal component for the 2m string is:
Tcos60
for the 1m string
mv^2/r
Now what? how would i figure out the tensions in each string?
unknowns
You really don't get unknowns, do you?
For problems like this, draw a clear diagram.
Label all the known lengths, forces, etc with numbers.
Label all the unknown ones with letters.
It's the only way to do it without making mistakes.
In this case, you've already labelled the tension in the top string T.
So label the tension in the bottom string U (for want of a better letter).
Then instead of:
warmfire540 said:
The horizontal component … for the 1m string
mv^2/r
you should write:
The horizontal component for the 1m string
U
You now have two equations … on the left-hand of each, are the total components forces in each direction … on the right-hand side, the acceleration in that direction! :smile:
Don't try to do these things in your head, or make assumptions … in this case, you somehow assumed the 1m string was supplying the centripetal acceleration, and because you hadn't given it a letter, you couldn't see a way out of it!​
So, given v=6m/s how would i find the two tensions on the strings
I suppose now i don't understand ALL the forces that are acting on both strings
I have drawings down but still don't get it
does the 2m string affect the 1m string? i figured only the angle on the 2m string was affected?
i can't figure out the tensions on both strings..
ooh … that's not a sensible physics question … physics is equations … you can only ask "do these two forces appear in the same equation?"
So … just do the equations in that order …
first, what is T (you don't need v for that)? :smile:
Well T is the tension..
for the 2m string Tsin60+tcos60=Tension
for the 1m string
There is no vertical component, only horizontal
so T=mv^2/r right?
Tension=2*36/1
Tension=72N for the smaller string
UNLESS some force in the 2m string affects this 72N
that's where I'm confused..is there a force making 72N greater or smaller?
No! :frown:
T is the tension in the top string.
To find it, just take vertical components of force. :smile:
tiny-tim said:
No! :frown:
Blah! confused..
Well, one string at time..the T (T) in the 2m string...:
T(2m)=Tcos60i+Tsin60j = 0.5Ti+0.87Tj
Obviosly I need to find T
for the 1m string:
U=mv^2/r = 72Ni
The sum of the x-componenets, and the sum of y-componenets must be zero since there is no net force right?
I don't know..i'm just confusing myself trying to find the tensions of both strings
Bad idea. :frown:
I agree that forces are vectors, and that what you have written is completely correct.
But in practice, it's usually a disaster to try to deal with more than one direction at a time.
So forget these vectors … just use one component at a time! :smile:
In this case, as you say:
the sum of y-components must be zero since there is no net force
So Tsin60º = mg.
Note that the reason we have done the y-compoonents first is that U and the acceleration are both horizontal … which makes the vertical equation particularly easy!
ok … that gives you T on a plate.
Now do the x components … that's more of a dog's dinner, with T U and the acceleration all taking part. But you know T by now, so that'll be ok. :smile:
tiny-tim said:
So Tsin60º = mg.
okay okay
so this is because the the ball is not changing it's direction vertically! right..the net force must be zero
So
Tsin60=mg
T=mg/sin60
T=22.6N
^^That is the tension in the 2m string..final.. velocity won't effect this...(right?)
Well T=22.6, U=centripital force?
It may be hard to intuitively imagine that the top string AND the bottom string are providing the centripetal force, but you have basically proven it to yourself now. Look at the tension T you found, the total force is 22.6N but the force in the y or vertical direction is only mg, so where is the rest of that string's force going?
--Bob
Bingo! :biggrin: You're getting the hang of this! :smile:
T=22.6N
^^That is the tension in the 2m string..final.. velocity won't affect this
S'right! Independent of velocity. :smile:
Nooo … don't take short-cuts …
(btw, it's "centripetal", with an e … the "pet" part means "seeking", as in "petition")
You need an equation with T and U on the left-hand-side, and acceleration on the right-hand-side.
Don't you? :biggrin:
hmmm..
mv^2=Tcos60+U
this is the centripetal force equals the x component of the 2m string and the tension on the 1m string (U)..
warmfire540 said:
mv^2=Tcos60+U
That's it! :smile:
(dont forget the "/r")
okay! yayy :biggrin:
so mv^2/r=Tcos60+U
72=22.6cos60+u 22.6cos60 = 11.3
6.4=u
the tension in the 1m string is 6.4N
is that all? that's it?!
problem solved?
erm … nayy! :biggrin:
… why did you divide? :rolleyes:
I've been having to work on my tension FBD skills as of late.
T = 72 N - (22.4/2) N (horizontal string tension)
T = 60.8 N
The centripetal force isn't actually a force. The centripetal force equations tells you how much force is needed to maintain a constant radius of curvature. As stated, the horizontal tension from string 1 and the horizontal component from string 2 give you this.
my bad, too much typing confused me
i got my final answer as U=60.7 N
sooo..this is it? I'm done?
:biggrin: Woohoo! :biggrin:
warmfire is … HOT! :smile: :devil: :smile:
( … if aok now, click on "Thread Tools" to mark the thread [SOLVED] … :wink: )
tiny tim! thank you so much, you've been a great help every step of the way!
17K
11K
