Checking convergence of Gaussian integrals
The discussion revolves around the convergence of Gaussian integrals, specifically focusing on the integral of the form Z(λ) involving exponential terms with quadratic and quartic components. Participants are exploring the conditions under which this integral converges and how to manipulate it for further analysis.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the separation of exponential terms in the integral and question the validity of applying series expansions. There are attempts to differentiate Z(λ) with respect to λ and to complete the square for simplification. Some participants express confusion over the relationship between Taylor series and derivatives.
There is an ongoing exploration of various methods to approach the integral, including series expansion and differentiation. Some participants have provided hints and partial results, but there is no explicit consensus on a single method or solution yet. The discussion remains productive with multiple interpretations being considered.
Participants are working under the constraints of homework guidelines, which may limit the extent of direct assistance provided. There are also indications of confusion regarding the application of certain mathematical techniques, such as completing the square and the implications of Taylor series.
JD_PM
Given
$$Z(\lambda) = \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} dx \exp\left( -\frac{x^2}{2!}-\frac{\lambda}{4!}x^4\right)$$
a) What is the range of ##\lambda## such that ##Z(\lambda)## converges?
b) Find a compact expression for the series expansion of ##Z(\lambda)## for small ##\lambda## of the form
$$Z_N(\lambda) = \sum_{n=0}^N c_n \lambda^n$$
Is your series convergent? What is the radius of convergence?
c) Find a series expansion for ##Z(\lambda)## for ##\lambda >> 1## of the form
$$\hat Z_N(\lambda) = \sum_{n=0}^N d_n \lambda^{\left(2n+1 \right)/4}$$
Is this series convergent? For what value of ##N## will you obtain a value for ##\hat Z_N(0,1)## which is close to the exact value ##Z(0,1)##.
N/A
a) First off, I computed the integral
\begin{align*}
Z(\lambda) &= \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} dx \exp\left( -\frac{x^2}{2!}-\frac{\lambda}{4!}x^4\right) \\
&= \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} dx \exp\left( -\frac{x^2}{2!}\right) \exp\left( -\frac{\lambda}{4!}x^4\right) \\
&= \frac{1}{\sqrt{2\pi}} \sqrt{2\pi} \left( \frac{(24)^{1/4}}{2(\lambda)^{1/4}} \Gamma\left( \frac 1 4 \right) \right) = \frac{(24)^{1/4}}{2(\lambda)^{1/4}} \Gamma\left( \frac 1 4 \right)
\end{align*}
So I would say that the range of convergence is ##\lambda \in (0, +\infty]##, am I right?
For b) and c) I am quite confused. I have been trying to naively apply the series expansion for the exponential i.e.
$$Z(\lambda) = \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} dx \exp\left( -\frac{x^2}{2!}-\frac{\lambda}{4!}x^4\right) = \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} dx \sum_{n=0}^{\infty}\left( -\frac{x^2}{2!}-\frac{\lambda}{4!}x^4\right)^n / n! \tag{*}$$
But I do not see how (*) could lead to get b) and c) expressions; could you please give me a hint :smile:
Thank you :biggrin:
a) You cannot integral ##e^{-x^2}## term and ##e^{-x^4}## term separately.
b) Try Taylor expansion of Z by ##\lambda##. We can get ##Z^{(n)}(0)## easily.
I see. How should I approach it then? I have been looking at Gaussian integral formulas; this is the best I could find
None of these fit the given integral though.
\begin{align*}
&= \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} dx \sum_{n=0}^{\infty}\left( -\frac{x^2}{2!}-\frac{\lambda}{4!}x^4\right)^n / n! \\
&\sim \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} dx \left[+1 -\frac{x^2}{2!}-\frac{\lambda}{4!}x^4 \right]
\end{align*}
So I would say that
\begin{equation*}
Z^{(n)}(0) = \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} dx \sum_{n=0}^{\infty}\left( -\frac{x^2}{2!}\right)^n / n!
\end{equation*}
But I do not see how the above will lead to get
$$Z^{(n)}(\lambda) = \sum_{n=0}^N c_n \lambda^n$$
b) Try differentiating Z by ##\lambda##. You will get
Z^{(1)}(0)=\frac{1}{\sqrt{2\pi}}\int_{-\infty}^{+\infty} e^{-x^2/2}x^4(-\frac{1}{24} )dx
Z^{(n)}(0)=\frac{1}{\sqrt{2\pi}}\int_{-\infty}^{+\infty} e^{-x^2/2}x^{4n}(-\frac{1}{24} )^n dx
You can get these values from the formula you found for a).
Why don't you complete the square and try again.
Alright, I get your results. Then we have
$$Z^{(n)}(\lambda)=\frac{1}{\sqrt{2\pi}}\int_{-\infty}^{+\infty} e^{-x^2/2 -\lambda/4! x^4}x^{4n}\left(-\frac{1}{24} \right)^n dx \tag{**}$$
But how to get ##Z^{(n)}(\lambda) = \sum_{n=0}^N c_n \lambda^n## out of ##(**)##?
Should I try
$$Z(\lambda) = \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} dx \exp\left[ -\left( x^2\sqrt{\frac{\lambda}{4!}} +\frac{x}{\sqrt{2}}\right)^2 + 2x^3 \sqrt{\frac{\lambda}{4!2}} \right]$$
With a change of variables ##u := x^2\sqrt{\frac{\lambda}{4!}} +\frac{x}{\sqrt{2}}## ?
I was thinking complete the square in terms of x^2, not in terms of adding a x^3 term but a constant term more like let y^2 = (a + bx^2)^2
Then I am afraid I do see the form you have in mind... might you please give me the explicit form, so that I can think how to solve it? :smile:
your job, it's your homework. It took me about 5 lines to do by myself.
You are right, let me try again. Did you solve the following integral
$$Z(\lambda) = \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} dx \exp\left[ -\left( x^2\sqrt{\frac{\lambda}{4!}} + \sqrt{\frac{3}{\lambda}}\right)^2 +\frac{3}{\lambda} \right]$$
With a change of variables ##u := x^2\sqrt{\frac{\lambda}{4!}} + \sqrt{\frac{3}{\lambda}}## ?
Have you considered expanding ##e^{-\frac{\lambda x^4}{4!}}## and integrating term by term against ##e^{\frac{-x^2}{2}}##?
The original form of the integral is exact, I found it in Gradshteyn and Ryzhik this afternoon after I started to look at the problem more closely.
You seem to confuse ##Z_N## Taylor series up to order N with ##Z^{(n)}## derivatives. ##c_n## is made from ##Z^{(n)} (0)##.
Dr Transport said:
Exactly... This should be tractable...
Alright so we have (I missed a 2 at #10)
$$Z(\lambda) = \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} dx \exp\left[ -\left( x^2\sqrt{\frac{\lambda}{4!}} + \sqrt{\frac{3}{2\lambda}}\right)^2 +\frac{3}{2\lambda} \right]$$
Labelling
$$a:= \sqrt{\frac{\lambda}{4!}}, \qquad b:= \sqrt{\frac{3}{2\lambda}}, \qquad c:= \frac{3}{2\lambda}$$
We end up with ##1 / \sqrt{2\pi} \exp(c) \int_{-\infty}^{\infty} \exp(-(ax^2 +b)^2) dx##. I thus got the form you suggested. Then I would use the change of variables ##y^2 = (ax^2 +b)^2 \iff y dy = 2ax(ax^2 +b)dx##.
But how to integrate
$$\frac{1}{\sqrt{2\pi}} e^c \int_{-\infty}^{\infty} e^{-y^2} \frac{1}{2a}\sqrt{\frac{a}{y-b}} dy$$
If you expand the e^{-\frac{\lambda}{4!}x^4} term, you do not have to complete the square to integrate the results term by term.
Sorry @Dr Transport I am a bit confused; are you suggesting to abandon the 'complete the square' method and go for a different method (the one suggested by @Fred Wright ) ?
@Dr Transport , @Fred Wright thank you, I start to understand! I get (let me drop out the normalization factor for now)
\begin{align*}
\int_{-\infty}^{\infty} dx \exp\left( -\frac{x^2}{2!} - \frac{\lambda}{4!}x^4 \right) &= \int_{-\infty}^{\infty} dx \exp\left( -\frac{x^2}{2!} - \frac{\lambda}{4!}x^4 \right) = \int_{-\infty}^{\infty} dx \exp\left( -\frac{x^2}{2!} \right) \exp\left( - \frac{\lambda}{4!}x^4 \right) \\
&= \int_{-\infty}^{\infty} dx \exp\left( -\frac{x^2}{2!} \right) \left[ 1 - \frac{\lambda}{4!}x^4 + \frac{\lambda^2}{1152}x^8 - \ ... \ \left(- \frac{\lambda}{4!} x^4\right)^n \frac{1}{n!} \right] \\
&= \int_{-\infty}^{\infty} dx \exp\left( -\frac{x^2}{2!} \right) - \frac{\lambda}{4!}\int_{-\infty}^{\infty} dx \exp\left( -\frac{x^2}{2!} \right)x^4 + \frac{\lambda^2}{1152}\int_{-\infty}^{\infty} dx \exp\left( -\frac{x^2}{2!} \right)x^8 - \ ... \ + \left(-\frac{\lambda}{4!}\right)^n \int_{-\infty}^{\infty} dx \exp\left( -\frac{x^2}{2!} \right) \frac{x^{4n}}{n!}\\
&= \sqrt{2 \pi} - \frac{\lambda}{2^{5/2}} \sqrt{\pi} + \frac{35}{3 \times 2^{13/2}} \sqrt{\pi} \lambda^2 - \ ... \ \text{I do not see the pattern} \\
&= \sum_{n=0}^N c_n \lambda^n
\end{align*}
Where the coefficients ##c_n## are given, as @mitochan stated, by the derivatives ##Z^{(n)}##
Next for me to understand is the range of convergence of this integral. Maybe I need to see the result of the the n-th integral first. I suspect that it should look similar to what follows
But instead of ##x^{2n}## we have ##x^{4n}##.
Might you please shed some light on how to compute the n-th integral and then on the range of convergence of the general integral? :smile:
I'm not sure exactly what you are looking for. You already have all the pieces in your post. (Don't multiply all the constants out as you seem to be doing.)
Use something like the ratio test to find the radius of convergence.
@JD_PM You see the pattern
c_n=\frac{Z^{(n)}(0)}{n!}
=\frac{(-)^n}{\sqrt{2\pi}}\frac{2}{(4!)^n n!}\int_{0}^{+\infty}x^{4n} e^{-\frac{x^2}{2}}dx=\frac{(-)^n}{\sqrt{\pi}}\frac{2^{2n+1}}{(4!)^n n!}\int_{0}^{+\infty}x^{4n} e^{-x^2}dx=...
c_0=1
Thank you all! I've been thinking and I would say I got section b) Let me argue it
\begin{align*}
Z(\lambda) &= \frac{1}{\sqrt{2 \pi}} \int_{-\infty}^{\infty} dx e^{-x^2/2!} e^{-\lambda x^4/4!} \\
&= \frac{1}{\sqrt{2 \pi}} \int_{-\infty}^{\infty} dx e^{-x^2/2!} \left( 1 - \frac{\lambda}{4!}x^4 + \ ... \ + \frac{(-)^n}{N!}\frac{\lambda^N}{(4!)^N}x^{4N} + ...\right) \\
&= \frac{1}{\sqrt{2 \pi}} \int_{-\infty}^{\infty} dx e^{-x^2/2!} \sum_{n=0}^N \frac{(-)^n}{n!}\frac{\lambda^n}{(4!)^n}x^{4n} \\
&= \frac{1}{\sqrt{2 \pi}} \sum_{n=0}^N \frac{(-)^n}{n!}\frac{\lambda^n}{(4!)^n} \left( \int_{-\infty}^{\infty} x^{4n} e^{-x^2/2} dx\right)
\end{align*}
Solving the integral (where I used the change of variables ##u:= x^2 / 2## and looked up the following integral ##\int_{0}^{\infty} e^{-n} x^{n-1} dx = \sqrt{n}##)
\begin{align*}
I= \int_{-\infty}^{\infty} x^{4n} e^{-x^2/2} dx &= 2\int_{0}^{\infty} x^{4n} e^{-x^2/2} dx \\
&= 2 \int_{0}^{\infty} (\sqrt{2t})^{4n} e^{-t} \frac{dt}{\sqrt{2t}} \\
&= 2 (\sqrt{2})^{4n - 1} \int_{0}^{\infty} t^{2n - 1/2} e^{-t} dt \\
&= (\sqrt{2})^{4n + 1} \sqrt{2n + \frac 1 2}
\end{align*}
We end up with
\begin{align*}
Z(\lambda) &= \frac{1}{\sqrt{2 \pi}} \sum_{n=0}^N \frac{(-)^n}{n!}\frac{1}{(4!)^n} (\sqrt{2})^{4n + 1} \sqrt{2n + \frac 1 2} \lambda^n \\
&= \sum_{n=0}^N c_n \lambda^n \\
\end{align*}
Mmm but I get ##c_0 = 1 / \sqrt{2 \pi}## instead of ##c_0 = 1##. So I guess I missed a ##\sqrt{2 \pi}## term when computing ##I## but I still do not see it though.
Thanks, using the ratio test I get that the integral is convergent and its radius of convergence ##R = \infty##. However, given that my computation of ##I## might be wrong, it may be wrong.
Thanks but might you shed some light on how did you go from the LHS to the RHS?
You should take better care of integration
\int_0^{+\infty} t^{2n-\frac{1}{2}}e^{-t}dt.
By partial integration
\int_0^{+\infty} t^{2n-\frac{1}{2}}e^{-t}dt=[ -t^{2n-\frac{1}{2}}e^{-t}]_0^{+\infty} - (-)(2n-\frac{1}{2})\int_0^{+\infty}t^{2n-\frac{1}{2}-1}e^{-t}dt=(2n-\frac{1}{2})\int_0^{+\infty}t^{2n-\frac{1}{2}-1}e^{-t}dt
= (2n-\frac{1}{2}) (2n-\frac{3}{2}) (2n-\frac{5}{2})...\frac{3}{2}\frac{1}{2} \int_0^{+\infty}t^{-\frac{1}{2}}e^{-t}dt=(2n-\frac{1}{2}) (2n-\frac{3}{2}) (2n-\frac{5}{2})...\frac{3}{2}\frac{1}{2}\ \ 2\int_0^{+\infty}e^{-t}d(\sqrt{t})
  • Love
\int_0^\infty x^{2n}e^{-ax^2}dx = \frac{1*3*5...(2n-1)}{2^{n+1}a^n}\sqrt{\frac{\pi}{a}}
figure it out from here n \to 2n
My apologies for the late reply
Indeed! I have noticed I made a mistake at #22. It is of course not a square root but a gamma function!\begin{align*}
&= (\sqrt{2})^{4n - 1} \Gamma \left( 2n + \frac 1 2 \right) \\
&= 2 (\sqrt{2})^{4n - 1} \frac{4n! \sqrt{\pi}}{2^{4n}(2n)!}
\end{align*}
This is how I got the last equality.
Hence we conclude that
\begin{align*}
Z(\lambda) &= \frac{1}{\sqrt{2 \pi}} \sum_{n=0}^N \frac{(-)^n}{n!}\frac{1}{(4!)^n} (\sqrt{2})^{4n - 1} \Gamma\left(2n + \frac 1 2 \right) \lambda^n \\
\end{align*}
Let us tackle c) now.
I am a bit confused here. How should we massage the original ##Z(\lambda)## so that we get the form ##\hat Z_N(\lambda)## has?
You can write down ##c_n## simply e.g. with no ##\sqrt{\pi}##.
Indeed, by means of
$$\displaystyle \Gamma\left(2n+ \frac 1 2 \right) = \frac{(4n)!\sqrt{\pi}}{2^{4n}(2n)!}$$
Any tips on how to approach c)? :) I am currently trying to find a method.
Why don't you continue calculation of post #23. I did not complete it because of homework policy.
= (2n-\frac{1}{2}) (2n-\frac{3}{2}) (2n-\frac{5}{2})...\frac{3}{2}\frac{1}{2} \int_0^{+\infty}t^{-\frac{1}{2}}e^{-t}dt=(2n-\frac{1}{2}) (2n-\frac{3}{2}) (2n-\frac{5}{2})...\frac{3}{2}\frac{1}{2}\ \ 2\underbrace{\int_0^{+\infty}e^{-t}d(\sqrt{t})}_{I_1}
I agree, let's finish the above computation first ;)
We see that ##(2n-\frac{1}{2}) (2n-\frac{3}{2}) (2n-\frac{5}{2})\cdots\frac{3}{2}\frac{1}{2} = \Gamma\left(2n+ \frac 1 2 \right)## . Now we should introduce a change of variables (I am not used to work with differentials with a square root, so I might have done a mistake). Setting ##x^2:=t## we get
$$\displaystyle I_1 = 2 \int_{0}^{\infty} x^2 e^{-x^2}\,{dx}$$
Now, there are several methods to solve this integral. I particularly liked the one involving differentiation of ##e^{-x^2}##
$$\frac{d^2}{dx^2}e^{-x^2}=-2e^{-x^2}+4x^2e^{-x^2} \tag{*}$$Taking the integral of ##(*)##'s LHS yields
$$\int_{0}^{\infty}\left(\frac{d^2}{dx^2}e^{-x^2}\right)dx=\frac{d^2}{dx^2}\int_{0}^{\infty} e^{-x^2}dx=\frac{d^2}{dx^2}\frac{\sqrt\pi}{2}=0$$
Taking the integral of ##(*)##'s RHS yields\begin{align*}
\int_{0}^{\infty} \left( -2e^{-x^2}+4x^2e^{-x^2}\right) dx = 0 \Rightarrow \int_{0}^{\infty} x^2 e^{-x^2}\,{dx} = \sqrt{\pi}/4
\end{align*}
Hence ##\displaystyle I_1 = \sqrt{\pi}/2## So
\begin{align*}
&(2n-\frac{1}{2}) (2n-\frac{3}{2}) (2n-\frac{5}{2})...\frac{3}{2}\frac{1}{2}\ \ 2\underbrace{\int_0^{+\infty}e^{-t}d(\sqrt{t})}_{I_1} \\
&= \sqrt{\pi} \cdot (2n-\frac{1}{2}) \cdot (2n-\frac{3}{2}) \cdot (2n-\frac{5}{2})\cdots\frac{3}{2} \cdot \frac{1}{2} \\
&= \frac{(4n)!\sqrt{\pi}}{2^{4n}(2n)!}
\end{align*}
Which leads to the expected final answer, shown #25
  • · Replies 105 ·
10K
