Checking set notation answers
11 replies · 2K views · last reply
Math100
Write each of the following sets by listing their elements between braces.
None.
Can anyone please check/confirm my answers if they are correct or not? I boxed around my answers just to be clear and understanding. Thank you.
  • Handwritten set notation work: 1) {3x+2 : x in Z} with values of 3x+2 for x = -2 to 6 listed, boxed result {...-4, -1, 2, 5, 8, 11, 14, 17, 20, ...}; 2) {x in N : -2 < x <= 7} boxed result {1, 2, 3, 4, 5, 6, 7}.
Math100 said:
Homework Statement:: Write each of the following sets by listing their elements between braces.
Relevant Equations:: None.
They look fine.
  • Love
Math100 said:
So my answers are correct?
Yes, although any thoughts on whether the second question is valid?
It looks ok. For (2), some people consider 0 to be a natural number.
It depends whether the notation, ##\{x \in \mathbb N: \dots \}## implies that ##\mathbb N## is the universal set under consideration. In that case, ##-2 \notin \mathbb N## and the comparison ##-2 < x## is not valid.
Or, if we consider that in all cases ##\mathbb N \subset \mathbb Z## and that it's valid to talk about ##-2## even when nominally restricting our attention to ##\mathbb N##, then it's fine.
I'm not saying one way or the other, but the question just didn't look right to me.
Thank you guys for the help! I really appreciate it!
What do you think? Is the condition ##-2 < x## valid for ##x \in \mathbb N##?
Yes.
By that reasoning, it would not be possible to say whether "1<x" is valid, since we could take the 1 as an element of that ##\mathbb Z## or ##\mathbb R##.
Similarly, I could not write x-1 since that is shorthand for x+(-1).
Seems more reasonable to apply the programming language concept of type coercion. An element of ##\mathbb N## can be 'elevated' to ##\mathbb Z## etc. as necessary to make the operation valid.
Whether the result can be demoted to conform to the target variable type is another matter.
Usually ##\mathbb R## is implied at the universal set and ##\mathbb Z \subset \mathbb R##.
The point about the question is that it explicitly defines the universal set as ##\mathbb N## and then talks about ##-2##, which is not defined within ##\mathbb N##.
Anyway, my main point is that it's definitely worth thinking about if you want to study pure maths,
If you are dealing with natural numbers, that can't be right, as natural numbers have no additive inverse. Instead ##n - m## is defined to be the natural number ##k## such that ##m + k = n##.
In general, ##n - m## is not well defined for all pairs of natural numbers. That IS important.
