Checking to see if I'm right or not.
  • Thread starter Thread starter Pinkshell4u
The discussion focuses on calculating the work done by gravity on a 50-kg jogger running up a 100 m hill at a 12-degree angle. The correct formula for work done by gravity is derived as W = -mgd sin(θ), leading to a final answer of -10,000 J. The initial incorrect calculation using potential energy (PEg = mgΔY) was clarified, emphasizing the importance of considering the component of distance in the direction of the gravitational force.
  • Understanding of gravitational force and weight (mg)
  • Basic trigonometry, specifically sine function
  • Knowledge of work-energy principles in physics
  • Familiarity with vector components and dot products
  • Study the concept of work in physics, focusing on the formula W = F * D
  • Learn about gravitational potential energy and its applications
  • Explore vector decomposition and its relevance in physics problems
  • Investigate the relationship between work, energy, and motion in different contexts
Students studying physics, particularly those focusing on mechanics and energy concepts, as well as educators looking for examples of work calculations involving gravitational forces.
Pinkshell4u
Checking to see if I'm right...or not.
A hill is 100 m long and makes an angle of 12 degrees with the horizontal. As a 50-kg jogger runs up the hill, how much work does gravity do on the jogger?
Do I use PEg=mgDelta Y ?
PEg = (50 kg) (9.8 m/s2) (100m) which equals 49,000 which is wrong. I know the answer is -10,000 J.
How and why? So confused...
work is
\int\vec{F}\bullet dr
to get rid of the dot product, you must take the parallel component of the distance that it is in the same direction of the force (gravity..which is down)
so you get :
-F*d*sin(\theta) = -mg*d*sin(\theta) = -(50)(9.8)*100*sin(12)
Oh, I think I get it. Thanks a lot.
no problem, remember that when you have the expression for work as:
F * D
that D is the change in distance, so say you climb a mountain than you climb back down than the work overall is zero since the change in position is zero
13K
  • · Replies 17 ·
  • · Replies 26 ·
