Chemical Kinetics - Rate Laws and Mechanisms
The discussion revolves around a homework problem related to chemical kinetics, specifically focusing on rate laws and reaction mechanisms for the reaction between nitrogen monoxide (NO) and bromine (Br2) to form nitrosyl bromide (NOBr). Participants are analyzing experimental data to derive the rate law, calculate the rate constant, and evaluate proposed reaction mechanisms.
  • Homework-related
  • Post 1 presents the experimental data and asks for the rate law, rate constant, concentration calculations, and evaluation of reaction mechanisms.
  • Post 1 claims the rate law is Rate = k[NO]^2[Br2] and provides a calculated rate constant of k = 1.2e4 L^2 mol^-2 s-1.
  • Post 1 expresses uncertainty about calculating the concentration of NO remaining when half of Br2 is consumed, suggesting a need for integrated rate laws or half-life equations.
  • Post 2 confirms the rate law and rate constant from Post 1 and suggests that for part (c), stoichiometry alone suffices to find the answer.
  • Post 3 questions whether the concentration of NO remaining would simply be half of the initial concentration, indicating a potential misunderstanding of stoichiometry.
  • Post 3 asserts that choice I of the proposed mechanisms is correct but seeks clarification on the reasoning behind it.
  • Post 4 provides a link for further explanation regarding reaction mechanisms, indicating a desire for more detailed information.
Participants generally agree on the correctness of the rate law and rate constant calculations. However, there is disagreement regarding the calculation of the concentration of NO remaining and the justification for the correct reaction mechanism, with some participants expressing uncertainty.
Participants have not fully resolved the calculations for part (c) and the reasoning for the choice of mechanism in part (d). There are assumptions about the applicability of stoichiometry and the interpretation of reaction mechanisms that remain unaddressed.
kazimmerman
This is straight off an old AP Exam, but I can't seem to find it online so I'm hoping you all can help me out.
2 NO(g) + Br2(g) --> 2 NOBr(g)
The following results were obtained in experiments designed to study the rate of the reaction above.
Experiment Initial Concentration (mol/L) Initial Rate of Appearance of NOBr(M/sec)
[NO] [Br2]
1 0.02 0.02 9.6e-2
2 0.04 0.02 3.8e-1
3 0.02 0.04 1.9e-1
(I'm not sure how to correctly display tables, so hopefully you can understand what everything is.
a) Write the rate law for the reaction.
b) Calculate the value of the rate constant, k, for the reaction. Include units.
c) In experiment 2, what was the concentration of NO remaining when half of the original amount of Br2 was consumed?
d) Which of the following reaction mechanisms is consistent with the rate law established in (a)? Explain your choice.
I. NO + NO --> N2O2 (fast)
N2O2 + Br2 --> 2 NOBr (slow)
II. Br2 --> Br + Br (slow)
2 (NO + Br --> NOBr) (fast)
Rate = k[A]^n^m
a) I've figured this out and I know I am correct with the following rate law:
Rate = k[NO]^2[Br2]
b) I also have this one confirmed correct:
c) This is where my problems begin. I am sure I should probably be splitting the rate law and using integrated rate laws and/or half-life equations, but I'm not completely sure where to begin. I know for second-order rates, half-life is:
t = (k[A](initial))^-1
and for a first-order reaction:
t = ln(2) k^-1
d) I understand mechanisms a bit, but I guess I don't know how to differentiate between which should occur.
Thanks ahead of time for any help. ;)
(a) and (b) look good.
For (c), you do not need to use any of the kinetics - only the stoichiometry of the balanced equation. Translating the equation into words: for every mole of Br2 consumed, there are 2 moles of NO consumed. This should lead you to the answer for (c).
(d) As far as mechanisms are concerned, a key point is that the overall rate is largely determined by the slowest step among a series of sequential steps that constitute the overall reaction. So, the essentials of the overall rate law should be extractable from the slow step.
So, for (c), wouldn't it also be half of the initial concentration of NO, .02?
And, as far as (d) goes, I know that choice I is correct, but I just don't understand why.
