CHEMISTRY: I filling out this flow chart for Group 1 Cations
The discussion focuses on filling out a flow chart for Group 1 Cations based on experimental results from a chemistry lab. The known substance tested positive for lead (Pb), mercury (Hg), and silver (Ag), while the unknown substance only tested positive for silver (Ag). Participants clarified that the flow chart should indicate what the solution may contain based on the presence of precipitates and the expected reactions, emphasizing the importance of identifying metal species when a precipitate forms.
  • Understanding of Group 1 Cations in qualitative analysis
  • Familiarity with precipitation reactions in chemistry
  • Knowledge of how to interpret laboratory results
  • Experience with flow charts in chemical analysis
  • Study the procedures for identifying Group 1 Cations using qualitative analysis
  • Learn about the role of precipitates in determining ion presence
  • Research the specific tests for lead (Pb), mercury (Hg), and silver (Ag) ions
  • Explore the use of flow charts in chemical experiments for better data organization
Chemistry students, lab technicians, and educators involved in qualitative analysis and the identification of cations in solutions.
WahooMan
Here is my lab:
http://comp.uark.edu/~rallan/Exp20.pdf
None that I know of
I ran the experiment once on a known substance and once on an unknown substance. Here are my results:
In the known substance, Pb Hg and Ag were all present according to the tests.
In the unknown substance, only Ag was present according to the tests.
I really need some help with this flow diagram (the last page that says Experiment 36).
Pretty much all I really need to know is how do I know what the "solution contains"? For example, the first part that is filled out for me says "Solution contains ions in Groups II and III" but how do I know that? And how do I know what to put in the other "solution contains" blanks?
Thank you so much to anyone that helps.
That's a little bit confusing. It is not that "Solution contains", it is "Solution may contain". What it really contains you will check later.
methods
So what should I put?
Thank you so much for your help I have class in 2 hours and I need to get this done.
If the test is negative (no ppt where one is expected) you put 'nothing'. If you have a ppt where one is expected (ie. when ammonia is added to the hot precipitate) you put 'name of the metal species'. For example, if you get a gray solid after treating the hot ppt of the HCl treatment, you would put 'Hg2+2' in that blank.
9K
