The discussion revolves around calculating the molecular formula of a gas compound consisting of boron (B) and hydrogen (H) in the context of stoichiometry. Participants are addressing a homework problem that involves determining the empirical formula, molecular weight, molecular formula, and the weight of boron trioxide (B2O3) produced from a combustion reaction.
- Homework-related
- Mathematical reasoning
- Technical explanation
- One participant proposes that the empirical formula is 2BH2 and calculates the molecular weight as 23.6378.
- Another participant suggests that to find the molecular formula, one must divide the molecular weight by the empirical weight, which is a necessary step to determine the integer multiplier for the empirical formula.
- There is confusion regarding the definition of empirical weight, with one participant mistakenly suggesting that it is the weight of the sample (0.596g).
- Participants clarify that the empirical weight should be the molar weight of the empirical formula, not the sample weight.
- One participant indicates that to find the empirical weight, one should sum the weights of the elements in the empirical formula.
Participants generally agree on the method to find the molecular formula but disagree on the definition and calculation of empirical weight. The discussion remains unresolved regarding the correct approach to determining the empirical weight.
There is a lack of clarity on the assumptions regarding the empirical formula and its molar weight, which affects the calculations presented. The discussion also highlights the need for precise definitions in stoichiometric calculations.
