Circuit Potential and Voltage Calculations
  • Thread starter Thread starter triplezero24
    Circuit Couple
To calculate the potential at point D in the circuit, first confirm that point A is grounded, which establishes a reference voltage of 0 volts. For the series capacitors connected to a 15-V battery, find the equivalent total capacitance and then calculate the total charge on this capacitor. From the total charge, determine the charge on each capacitor to find the voltage across the 32 microFarad capacitor. Additionally, use Kirchhoff's Voltage Law (KVL) to find the current in the circuit and subsequently the voltage drops across the resistors to ascertain the potential at point D. Accurate calculations require careful attention to signs and proper understanding of series and parallel capacitor combinations.
triplezero24
1. For http://www.pen.eiu.edu/~cuemc4/circuit.bmp picture.. Calculate the potential at point D.
2. I 15-V battery is connected to three capacitors in series. The capacitors have the following capacitances: 4.5microFarads, 12.0microFarads, and 32microFarads. Find the voltage across the 32microFarad capacitor.
I am so lost. :frown:
Please? I'm desperate!
I couldn't open your first picture... I get a "server not found" message.
For the second one... first find the equivalent total capacitance (combine 3 capacitors in series). The find the total charge on this equivalent capacitor.
You should then be able to get the charge on each capacitor (hint: this is really simple... if you are unsure read your textbook regarding combining series and parallel capacitors), and then get the voltage on each capacitor.
That might work. Mak sure you're soomed in all the way or it won't look right. Thanks for the help so far!
New link doesn't work either.
I'll attatch it.
Hmmm... absolute potential can't be calculated unless there's ground assigned somewhere. But I don't see one on the circuit. Are you sure the question asks for potential at D and not potential difference between 2 different points? Does the question mention about 0 volts being assigned somehwere?
Sorry. It says point A is grounded (V=0).
ok cool. So first find the current I in the circuit using KVL. So then you can get all the voltage drops across all the resistors (voltage drop across a resistor=current*resistance). Using that you should be able to find the potential at D. Be careful with signs!
Hope this helps!
