Circuit y(t)=|x(t)|, LIT system?
  • Context: Engineering
  • Thread starter Thread starter znaya
    Circuit System
7 replies · 2K views
znaya
Consider a circuit which output is the absolute value of the input signal, this is, y(t)=|x(t)|?
a) this circuit is not a LIT system because it implements a non linear operation;
b) this circuit is a LIT system that creates phase distortion;
c) this circuit is a LIT system that creates amplitude distortion;
d) this circuit is a LIT system that creates amplitude and phase distortion.
My first thought was... it's not linear because it will "convert" only the negative part of the sinusoid but then... isn't this because of the phase? I can't decide between a) and b).
Could someone please give a help?
To answer a mathematical question, you should think in terms of mathematics. What's the mathematical definition of a linear time independent system (- if that's what "LIT" abbreviates. The more common abbreviation is "LTI".)
it means that the system will do the same no matter what time...
That isn't a mathematical description. Look up the mathematical definition of an LTI system. What mathematical laws must it follow?
I think you mean LTI: Linear Time invariant.
for a system to be LTI it has to meet to criteria.
1. it has to be linear
(S is a system operator)
S [ x1(t) + x2(t)] = S [x1(t)] + S [x2(t)]
and
S [ a x1(t) ] = a S [x1(t) ]
2. it has to be time invariant
y(t - T) = S [x(t - T)]
for any T or t
so znaya, does your function meet the first criteria?
use two inputs, say -2 and 2
http://www.icoachmath.com/math_dictionary/Linear_Function.html
Definition of Linear Function
A function that can be graphically represented in the Cartesian coordinate plane by a straight line is called a Linear Function.
and
for any T or t
for x=-2, y=2
for x=2, y=2
for x=(2+(-2)) y=0
i see...
so it seems my first thought was right...
Stephen Tashi, donpacino, thank you so much for your help.
