Circuits with Series and Parallel Wiring
The discussion revolves around a circuit problem involving series and parallel resistors, specifically two 10-ohm resistors, a 20-ohm resistor, and a 6-ohm resistor. Participants express confusion about the configuration of these resistors and how to approach the problem using known equations for series and parallel circuits.
  • Participants attempt to identify the arrangement of resistors, questioning whether certain resistors are in series or parallel. There are discussions about redrawing the circuit for clarity and the implications of current flow through different components.
The discussion is active, with various interpretations of the circuit configuration being explored. Some participants provide insights into the relationships between the resistors and current flow, while others express uncertainty about how to proceed with calculations. There is no explicit consensus on the correct approach yet.
Participants mention the need for voltage information to solve for current and discuss the implications of Kirchhoff's laws in relation to the circuit. There are indications of confusion regarding the readings of the ammeter and the calculations of current through the resistors.
  • #31
NascentOxygen said:
They don't? http://img690.imageshack.us/img690/3484/hidden17.gif
How much current is flowing in just one of the 10Ω resistors?
.8 amps?
  • #32
Snape1830 said:
.8 amps?
Then I2·R =
and what makes you think this isn't right?
  • #33
NascentOxygen said:
Then I2·R =
It would be 6.4, and it's wrong because I plugged in the answer and it said it was wrong.
  • #34
6.4 watts is correct.
  • #35
Oh, right yeah, I just didn't put the decimal point in. Silly me.
Thanks!
  • #36
questions like these can be solved in your head!
first, for the current, the net resistance of the topmost two resistors is 5 ohm. now, the reciprocal of 5 is .2 and the reciprocal of 20 is .05 as you should be able to do immediately. they add up to be .25 - which is the reciprocal of the net resistance of the equivalent resistor containing the 20 ohm resistor and also the reciprocal of 4. so, to date, the net resistance is 4 ohms and this adds to the 6 ohms resistor in series. now, clearly, the net current through the battery is 20/(6+4) A = 2 A. this 2 A current divides in two sections in the ratio 4:1 (the current varies inversely as the resistance with p.d. constant). so, the current going through the ammeter is 2[itex]\times[/itex]4/5 = 16/10 = 1.6 A.
for the power, the current 1.6 A just divides in two equal parts, so it's .8 A through each 10 A resistor. so, the power dissipated is 10[itex]\times[/itex].82 = 6.4 W.
so, don't use the loop and the junction rules unless you really need them. they'll mess up everything. try to solve this kinds of problems intuitively or using the method I've described - they are really easy.
