Circular conductor with changing T effecting power and magnetic field
2 replies · 1K views · last reply
Helmholtz
When we keep a circular copper (ohmic) conductor at a constant temperature T_1, thermal energy is produced along it at a rate P_1 and the magnetic field at its center has magnitude B_1. Then, we heat the conductor to a higher constant temperature T_2 (i.e. T_2>T_1). At temperature T_2, let P_2 and B_2 be the rate of dissipation of energy and the magnitude of the magnetic field at its center respectively. Which of the following is TRUE, if ALL other factors remain the same?
(A) It holds that B_1<B_2 and P_2=P_1.
(B) It holds that B_1>B_2 and P_2<P_1.
(C) It holds that B_1=B_2 and P_2=P_1.
(D) It holds that B_1<B_2 and P_2>P_1.
(E) It holds that B_1=B_2 and P_2>P_1.
Not really sure
Looking for a starting point
Not really sure
You really need to show some effort when posting a question here. At least in your other threads so far, you've shown a bit of effort. Normally this thread would get deleted with a warning, but instead I'll ask a question to try to get you started.
What is the equation for the conductivity of metal versus temperature? That should be enough of a hint to allow you to solve this question.
BTW, do they specify *how* they are heating the wire? Is it connected to a constant voltage source to produce the current that makes the B field?
