Circular cylinder integral question
The forum discussion centers on calculating the electric field generated by a charged circular cylinder. Participants clarify the use of Pythagorean theorem to determine the distance from the charge elements to the observation point, emphasizing the need for double integrals when considering contributions from small segments of the ring. The conversation also addresses the distinction between using a small part of the ring versus the entire ring, ultimately converging on the conclusion that both approaches yield equivalent results. The final calculations involve integrating the charge density and applying the appropriate limits to derive the electric field expression.
  • Understanding of electric field concepts and formulas, specifically for charged bodies.
  • Familiarity with calculus, particularly double integrals and integration techniques.
  • Knowledge of Pythagorean theorem as it applies to three-dimensional geometry.
  • Experience with LaTeX for mathematical notation and expressions.
  • Study the derivation of electric fields from continuous charge distributions using double integrals.
  • Learn about the application of Pythagorean theorem in electrostatics, particularly in cylindrical coordinates.
  • Explore Example 23.9 in textbooks to understand electric fields generated by solid discs.
  • Practice writing complex mathematical expressions in LaTeX for clarity in presentations and discussions.
Students and professionals in physics and engineering, particularly those focusing on electromagnetism and electrostatics, will benefit from this discussion. Additionally, anyone involved in advanced calculus or mathematical physics will find the insights valuable.
transgalactic
the question is here:
http://i42.tinypic.com/9j2alv.gif
the charge on one small ring is
<br /> dq=\frac{Qdx}{h}\\<br />
the problem is with the distance squared part
its constantly changes
i don't know how to write in the distance square part
<br /> E=\frac{kQ }{h} \int_{h+d}^{d}d x<br />
and it a ring not a small particle
so the normal formula of a field kq/r^2
is not logical here
Just use Pythagoras :smile:
(and the result of Example 3.8)
this is the solution:
http://i40.tinypic.com/2d14t2.gif
regarding part a:
it seems that they use one ring at a time.
but the Pythagorean distance suggests that they use only a small part from that ring.
if they use only a small part of a ring then the whole this should be a double integral
one for the sum of every small part of a ring
the other is for all rings.
but if they use one ring at a time then they should take the distance from the center of a ring to the point,not the Pythagorean distance of a small part from a ring
transgalactic said:
… but if they use one ring at a time then they should take the distance from the center of a ring to the point,not the Pythagorean distance of a small part from a ring
No … they're using √(x2 + R2),
which is the distance from every part of the ring (in other words, for every value of theta) …
I agree if the ring wasn't circular, then those distances would be different, and you'd need a second integral (over theta) …
but they're the same, so the field is exactly the same as if all the mass of the ring were concentrated in one part :smile:
i don't know how to choose a small part of a ring:
first way:
dtheta is a small angle from from the center of a ring.
i say that the whole ring is 2pi so a small part of that ring is dtheta/2pi
<br /> dq=\frac{Qdx}{ h}\frac{d\theta}{2\pi}<br />
the other way is saying that dx is the width and r*dtheta is the length of that small
square.the density is \frac{Q}{2\pi r h}
so i get
<br /> dq=\frac{Q}{ h2\pi r}dx Rd\theta<br />
what way of choosing a small part is wrong?
They're both right!
(I'm assuming you meant r not R in the second one :wink:)
If you cancel the r/r, they're the same.
So you can either do it that way, which gives you a ∫∫dr dθ, and the integral doesn't depend on θ, so you can immediately integrate wrt θ and get 2π times the ∫dr, which cancels out the 2π on the bottom
or you can do what the book does, which is to take the whole ring together, which had no 2π on the bottom, so it comes out the same. :smile:
in the second one:
i meant R
because the radius is R do its dR
is it ok?
i can't understand the whole ring method:
why they do sqrt(R^2+X^2) if its a whole ring and not a small part of it
(hmm … just noticed I kept typing ∫dr when I meant ∫dx in my last post :redface:)
transgalactic said:
in the second one:
i meant R
is it ok?
Yup … I got confused between R and r :redface:
but then you should have had 2πR on the bottom instead of 2πr, and the R/R still cancels. :wink:
Perhaps I'd better write it out in full …
∫∫ (Qdx/2πRh)√(x2 + R2) dx Rdθ
= ∫ [∫ (Qdx/2πh)√(x2 + R2) dx] dθ
= 2π[∫ (Qdx/2πh)√(x2 + R2) dx]
= ∫ (Qdx/h)√(x2 + R2) dx,
which as you can see is what the book does …
and it woks because the √(x2 + R2) is the same at all points on the ring :smile:
this is my calculations.
i got got a different double integral then you
why??
<br /> dq=\frac{Q}{ h2\pi R}dx Rd\theta\\<br />
<br /> \cos \alpha=\frac{x}{\sqrt{x^2+R^2}}\\<br />
<br /> k\int_{d}^{h+d}\int_{0}^{2\pi}\frac{dq}{(R^2+x^2)}\cos \alpha=<br /> k\int_{d}^{h+d}\int_{0}^{2\pi}\frac{x\frac{Q}{ h2\pi R}dx Rd\theta}{(R^2+x^2)^{\frac{3}{2}}}\\<br />
oh yes … I forgot about the cosine :biggrin:
i solved the integral but i get an expression which differs a lot from the books answer
where is the mistake
<br /> k\int_{d}^{h+d}\int_{0}^{2\pi}\frac{x\frac{Q}{ h2\pi R}dx Rd\theta}{(R^2+x^2)^{\frac{3}{2}}}=k\int_{d}^{h+d}\frac{x\frac{Q}{ h2\pi R}dx R(2\pi-0)}{(R^2+x^2)^{\frac{3}{2}}}=\frac{kQ2\pi}{2\pi h}\int_{d}^{h+d}\frac{xdx}{(R^2+x^2)^{\frac{3}{2}}}\\<br />
<br /> R^2+x^2=t\\<br />
<br /> 2xdx=dt\\<br />
<br /> \frac{kQ}{ 2h}\int_{R^2+d^2}^{R^2+h^2+2hd+d^2}\frac{dt}{t^{\frac{3}{2}}}=<br /> \frac{kQ}{ 2h}\int_{R^2+d^2}^{R^2+h^2+2hd+d^2}{-2t^{\frac{-1}{2}}}\\<br />
the last part is not an integral i just don't know how to write this straight line with intervals on it in LATEX code.
so its like that straight line on the right side.
Well, that looks ok so far.
Maybe the ends of the cylinder are supposed to be solid also (it isn't clear from the question)?
What answer does the book give? :smile:
But that is the same as your solution :smile:
(assuming, in your last line, the ∫… is really a […] :wink:)
wow i think i solved it i got identical expression.
HIP HIP HOORAY.
ok now in part b:
its a solid cylinder .
i need to take a 3d small part
i divide the cylinder into small plates
the density is \frac{Q}{\pi r^2 h}
dq=\frac{Q}{\pi r^2 h}rd\theta dr
but i am not sure regarding the dr part
i know that our radius is temporaty
why i can't write dR
i can't see how the dr part changes from one radius to the other
we can have a constant length that stays the same for every radius and get the same result
correct
HIP HIP HOORAY.
You're easily pleased! :biggrin:
ok now in part b:
correct
I'm not really following this :confused:
The answer in the book uses the formula for the field at distance x from a solid disc …
why don't you go back to Example 23.9, and see how they got it? :smile:
transgalactic said:
23.8 is not about disks at all
http://i44.tinypic.com/2lihmjn.gif
That's strange … part b clearly ends "Use the result of Example 23.9 to find the field it creates at the same point"
regarding part b:
is it ok to write dR instead of dr(we take a small part of radius R,not r)
Yes … in fact, you must, because R is fixed …
you'll get the whole of one disk by integrating over dr from r = 0 to r = R. :smile:
  • · Replies 38 ·
