What is the Maximum Radius for a Bucket of Water in Circular Motion?
The maximum radius for a bucket of water swung in a vertical circle can be determined using the centripetal force equation, Fc = mv²/r. Given a mass of 3.75 kg and a speed of 6.20 m/s at the top of the loop, the gravitational force (Fg) acting on the bucket is -9.81 m/s². By equating the centripetal force to the gravitational force at the top of the loop, the maximum radius can be calculated, ensuring the water remains in the bucket throughout the motion.
  • Centripetal force concepts
  • Understanding of gravitational force
  • Basic algebra for solving equations
  • Knowledge of circular motion dynamics
  • Calculate the maximum radius using the formula r = mv²/Fg
  • Explore the effects of varying speed on the radius in circular motion
  • Investigate the differences in circular motion on different celestial bodies
  • Learn about the implications of centripetal acceleration in real-world applications
Students studying physics, educators teaching circular motion concepts, and anyone interested in the dynamics of forces in motion.
Redjakk1
A 3.75 kg bucket pile of water is swung in a vertical circle. If the speed of the bucket at the top of the loop is 6.20 m/s, then the radius of the largest circle through which this pail could move without the water leaving the bottom of the pail would be what?
m = 3.75 kg
v = 6.20 m/s
r = ?
I was thinking to use Fc = mv^2/r but I'm not given Fc. I'm not sure what formula I should use or how to go about solving this question. Any help would be greatly appreciated.
Step 1 read the question. Step 2 is to reread the question for the information you need.
What do you mean?
It's stated all over the forum that you are going to have to do some of the work. If I quote a piece of your original post, that is what is called a "hint."
Well I sort of figured that. I'm not trying to get out of doing the work, I'm just not sure what formula I should use or how I should go about the question.
Does the question place you specifically on the Moon? Or Mars? Or elsewhere in the solar system? You may assume that you are on the Earth's surface.
So g = -9.81. Is Fc equal to Fg or something like that then ?
Makes a good place to start.
  • · Replies 19 ·
  • · Replies 21 ·
