Circular Motion of a turntable spinning counterclockwise
The problem involves a turntable of radius "r" that is initially spinning counterclockwise at a rate of ω, which then slows down uniformly until it stops at time T. The main question is to determine when the centripetal acceleration of a point on the rim is half of its initial value, expressed in terms of T.
  • Participants discuss the relationship between centripetal acceleration and angular velocity, questioning how to express the conditions for the acceleration to be halved. There are attempts to relate the change in ω over time to the desired acceleration condition.
Participants are actively exploring the implications of the centripetal acceleration formula and how changes in ω affect it. Some have proposed specific time points (e.g., T/2, T/3) for when ω reaches certain fractions of its initial value, while others are questioning the correctness of these assumptions. Guidance has been provided regarding the relationship between ω and the required centripetal acceleration.
There is an ongoing discussion about the implications of the turntable's uniform deceleration and how it affects the calculations. Participants are also considering the need for additional mathematical concepts to fully understand the relationships involved.
Dan22
A turntable of radius "r" is spinning counterclockwise at an initial rate of ω. at t=0, its rotation rate begins to slow at a steady pace. the rotation finally stops at t=T. At what time during the time interval 0<t<T was the magnitude of the centripetal acceleration of a point on the turntable's rim equal to half its initial value? Express the answer in terms of T
centripetal acceleration=ω^2r
ω=ω°+αt ?
Δθ=ω°t+.5αt^2
got about a page and a half of hand written notes right here and nothing to show for it. not really sure where to start, and definitely not sure how to right equation in terms of T. any suggestions are appreciated
ω=ω°+αt ?
Δθ=ω°t+.5αt^2
The expression for centripetal acceleration is where you need to start.
a = ω2r
you want that value to halve, but without the value of "r" changing, so what must happen to the value of ω and when will that happen?
a = ω2r
i'm honestly not sure how to determine what ω needs to be nor when it will get there. ω^2 obviously has to be half as large but I'm not sure where to go from there
At what time will ω be 1/2 its original value?
At what time will ω be 1/3 its original value?
At what time will be 57% of its original value?
If ω2 is to be half as large, what must the value of ω be?
ω will be at half its original value at 1/2t. but what can i do with that?
Dan22 said:
wow, duh it will ω will be at half its original value at 1/2t. but what can i do with that?
1/2 is the easy one [though it should have been 1/2T I believe] Edit: and T/2 would be a better way of saying that.
try the other two.
try the other two.
do you mean when ω will be at 1/3ω and 57%ω. wouldn't that just be at T/3 and .57T. not sure why i would need those to be honest.
i'm still having trouble figuring out what ω needs to be for ω^2 to be half the size
I suspected you might say that. Both those answers are wrong.
Will the turntable have slowed to 1/3 its speed before or after it has slowed to half its speed?
is T/3 before or after T/2 ?
for ω^2 to be half its size would ω= [α/(2r)]^.5 ? or am i just thinking myself in circles?
man I'm feeling stupid right now, it would be at 1/3 of its speed at 2/3T and at 57% of its speed at .43T right?
That's better.
Now, suppose ω was originally 10. That would mean ω2 would be 100
What value would ω have to be for ω2 to be 50 ?
7.0711 instead of 10, and i didn't expect that to be a fixed relationship but it seems to be. so for ω^2 to be one half of that ω=.70711ω though i expect that there is a neater form of that
So W has to reduce to 70.71% of its original value. I am now confident you will be able to find when that happens.
By the way - the neater form is ω/√2 and of course 1/√2 = √2 / 2 and √2 / 2 = 1.414/2 = 0.707EDIT: a quick course in "variation" - a mathematics topic - would be very handy at some stage. So much of Physics is dealt with in a Variation way.
eg: How does the speed of a satellite change of its radius of orbit is doubled. What is the value of g [9.8 at the surface of the Earth] if we move to a position 5R from the centre of the Earth. How about 5R from the surface of the Earth.
so the answer is t=.2929T is that correct. pretty sure it is, and thank you very much you were very helpful. willing to help with part b?
What is part b?
I am about to leave my computer for 36 hours, so won't reply immediately.
PeterO said:
What is part b?
no problem, i think i got this it just has to do with finding at what time ω^2t is greatest pretty sure i got this, thanks for all your help,
  • · Replies 20 ·
